comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/8013205
Add CPU port type CPU_Exception_frame and function
_CPU_Exception_frame_print().
The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh,
sparc64, and v850 use an empty default implementation of
Add rtems_exception_frame and rtems_exception_frame_print().
Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions. Use rtems_fatal()
with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc,
and sparc for unexpected exceptions.
Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the
BSP_PRINT_EXCEPTION_CONTEXT define used in the default
bsp_fatal_extension().
Add test sptests/spfatal26.
Add and use new CPU port define CPU_SIZEOF_POINTER. It must be an
integer literal that can be used by the assembler. This value will be
used to calculate offsets of structure members. These offsets will be
used in assembler code.
The size of a pointer is part of the application binary interface (ABI)
and thus independent of the actual programming language. The compiler
will provide defines to determine the current ABI. We use these defines
to select the appropriate CPU_SIZEOF_POINTER value.
Static assertions in the new file "cpukit/score/src/percpuasm.c" will
ensure that the value of CPU_SIZEOF_POINTER is consistent with the
current compiler settings. Also the offset values used by assembler
code are verfied.
for details.
Add
o _Nios2_MPU_Get_region_descriptor(), and
o _Nios2_MPU_Set_region_registers().
This fix is critical. The previous implementation leads to system
corruption.
* nios2-mpu-configuration.c, nios2-mpu-descriptor.c,
nios2-mpu-disable-protected.c, nios2-mpu-reset.c: New files.
* rtems/score/nios2-utility.h, nios2-context-initialize.c: Added
support for the memory protection unit (MPU).
* nios2-context-switch.S: Use small-data area access for
_Per_CPU_Information fields.
PR 1914/cpukit
* rtems/score/cpu.h: Select timestamp implementation.
* nios2-eic-il-low-level.S, nios2-eic-rsie-low-level.S: New files.
* rtems/score/cpu.h, rtems/score/nios2-utility.h,
nios2-thread-dispatch-disabled.c, nios2-context-switch.S: Added
support for thread stack protection via the MPU.
* rtems/score/cpu.h: Request cache alignment and small data area in
CPU_STRUCTURE_ALIGNMENT.
* nios2-thread-dispatch-disabled.c: Use offsetof() instead of
RTEMS_offsetof().
* rtems/score/nios2-utility.h, nios2-isr-set-level.c,
nios2-isr-get-level.c: Renamed functions.
* rtems/score/nios2-utility.h: Use the same values for defines used by
Altera HAL.
* rtems/score/nios2-utility.h: Avoid redefines with Altera HAL.
Declare _Nios2_ISR_Set_level().
* nios2-context-initialize.c: Use _Nios2_ISR_Set_level().
* nios2-isr-set-level.c: Define _Nios2_ISR_Set_level().
* cpu.c, cpu_asm.S: Removed files.
* nios2-context-initialize.c, nios2-context-switch.S,
nios2-fatal-halt.c, nios2-initialize-vectors.c, nios2-initialize.c,
nios2-isr-get-level.c, nios2-isr-install-raw-handler.c,
nios2-isr-install-vector.c, nios2-isr-is-in-progress.c,
nios2-isr-set-level.c, nios2-thread-dispatch-disabled.c,
rtems/score/nios2-utility.h: New files.
* Makefile.am, preinstall.am: Reflect changes above.
* irq.c: Update due to API changes.
* rtems/score/cpu.h: New functions _CPU_Initialize_vectors(),
_CPU_ISR_Set_level(), and _CPU_Fatal_halt() (instead of macros).
Support for external interrupt controller (EIC). Documentation
changes.
* cpu.c: Fix the ISR get level for the IIC. Make
_CPU_Context_Initialize a function rather than inlined.
* cpu_asm.S: Do not enable interrupt on return, rather resume the
state on entry to the ISR.
* irq.c, nios2/nios2-iic-low-level.S: Change the ISR handler so
the ipending decoding is in C and within the interrupt
context. This is usable with the Altera HAL directly.
* rtems/score/cpu.h: Add ienable and ipending interfaces. Add some
comments. Remove _CPU_Context_Initialize.
* rtems/score/cpu.h: Clear the vector table for simple vectored
interrupts.
* irq.c: Add support for using the IIC with the Altera HAL.
* rtems/score/cpu.h: Removed superfluous comments. Format. Include
by assembler support. Removed superfluous floating-point support.
Stack alignment is now 4.
* rtems/score/cpu.h, cpu.c: Removed superfluous functions.
* nios2-iic-low-level.S: New file.
* cpu_asm.S: Moved low-level interrupt handling into new file.
* Makefile.am: Reflect change from above.
* cpu_asm.S, rtems/score/cpu.h: There is no need to save the global
pointer (gp) in the thread register context since it is a system wide
constant and set-up with the C runtime environment.
* cpu.c: Remove /*PAGE markers which were interpreted by a long dead
print script.
* Makefile.am: Reformat.
PR 1777/cpukit
* libcsupport/src/malloc_deferred.c, libcsupport/src/realloc.c,
score/Makefile.am, score/cpu/lm32/irq.c, score/cpu/nios2/irq.c,
score/inline/rtems/score/thread.inl, score/src/heapfree.c,
score/src/pheapwalk.c, score/src/smp.c, score/src/threaddispatch.c:
Consolidated access to _Thread_Dispatch_disable_level.
* score/src/threaddisabledispatch.c, score/src/threadenabledispatch.c:
New files.
* irq.c:
* rtems/score/cpu.h: Add RTEMS_COMPILER_NO_RETURN_ATTRIBUTE to
_CPU_Context_restore() because it does not return. Telling GCC this
avoids generation of dead code.
PR 1599/cpukit
* irq.c: Rename _Context_Switch_necessary to _Thread_Dispatch_necessary
to more properly reflect the intent.
PR 1635/cpukit
* rtems/score/cpu.h, rtems/score/types.h: Refactoring of priority
handling, to isolate the bitmap implementation of priorities in the
supercore so that priority management is a little more modular. This
change is in anticipation of scheduler implementations that can
select how they manage tracking priority levels / finding the highest
priority ready task. Note that most of the changes here are simple
renaming, to clarify the use of the bitmap-based priority management.
* rtems/score/cpu.h: Include <rtems/score/types.h> first.
* rtems/score/types.h: Use <rtems/score/basedefs.h> header file.
PR 1573/cpukit
* irq.c, rtems/score/cpu.h: Add a per cpu data structure which contains
the information required by RTEMS for each CPU core. This
encapsulates information such as thread executing, heir, idle and
dispatch needed.
* cpu.c, cpu_asm.S, irq.c: Add include of config.h
* cpu_asm.S: Eliminate extern of unused variables.
* cpu.c: Remove stray semi-colon.
* cpu.c, rtems/score/cpu.h: Change prototype of IDLE thread to
consistently return void * and take a uintptr_t argument.
* cpu.c, rtems/score/cpu.h: Eliminate _CPU_Thread_dispatch_pointer and
passing address of _Thread_Dispatch to _CPU_Initialize. Clean up
comments.
* rtems/score/types.h: Do not define boolean, single_precision,
double_precision unless RTEMS_DEPRECATED_TYPES is given.
* configure.ac, aclocal/canonical-target-name.m4: Readd NIOS2 and TI
C4x. Accidentally not done on 4.9 branch. :(
* score/cpu/c4x/.cvsignore, score/cpu/c4x/ChangeLog,
score/cpu/c4x/Makefile.am, score/cpu/c4x/cpu.c,
score/cpu/c4x/cpu_asm.S, score/cpu/c4x/irq.c,
score/cpu/c4x/preinstall.am, score/cpu/c4x/rtems/asm.h,
score/cpu/c4x/rtems/score/c4x.h, score/cpu/c4x/rtems/score/cpu.h,
score/cpu/c4x/rtems/score/cpu_asm.h,
score/cpu/c4x/rtems/score/types.h, score/cpu/c4x/rtems/tic4x/c4xio.h,
score/cpu/nios2/.cvsignore, score/cpu/nios2/ChangeLog,
score/cpu/nios2/Makefile.am, score/cpu/nios2/cpu.c,
score/cpu/nios2/cpu_asm.S, score/cpu/nios2/irq.c,
score/cpu/nios2/preinstall.am, score/cpu/nios2/rtems/asm.h,
score/cpu/nios2/rtems/score/cpu.h,
score/cpu/nios2/rtems/score/cpu_asm.h,
score/cpu/nios2/rtems/score/nios2.h,
score/cpu/nios2/rtems/score/types.h: New files.
* configure.ac, aclocal/canonical-target-name.m4,
score/cpu/Makefile.am: Remove TI C4x and NIOS2 ports from 4.9 branch.
score/cpu/nios2/rtems/score/types.h: Removed.
* rtems/score/cpu.h: Remove extraneous spaces.
