path: root/cpukit/score/Makefile.am (follow)
* 2004-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-191-2/+4
| | | | * Makefile.am: Add PREINSTALL_DIRS.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-141-0/+6
| | | | | | * Makefile.am: Re-add dirstamps to PREINSTALL_FILES. Add PREINSTALL_FILES to CLEANFILES. Add cpuopts.h to DISTCLEANFILES.
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-111-2/+1
| | | | * Makefile.am: Include compile.am, again.
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-091-1/+3
| | | | | * Makefile.am: Add libs to CLEANFILES Set lib*_g_a_SOURCES = lib*_a_SOURCES.
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-091-7/+7
| | | | | * Makefile.am: Build libscore$(LIB_VARIANT).a instead of $(ARCH)/libscore.a.
* 2004-01-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-071-14/+8
| | | | * Makefile.am: Build library using EXTRA_LIBRARIES and automake rules.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-4/+2
| | | | * Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-011-2/+2
| | | | | * Makefile.am: Add $(dirstamp) to preinstallation rules. Remove MACROS.
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-301-159/+158
* 2003-11-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-231-100/+402
| | | | * Makefile.am: Don't use gmake to preinstall.
* 2003-08-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-08-141-1/+2
| | | | | | | | | * Makefile.am, include/rtems/score/object.h, include/rtems/score/objectmp.h, src/objectmp.c, src/objectnametoid.c: Added ID to name lookup service and changed name of id/name translation status code. This propagated to multiple functions. The user API service added was rtems_object_id_to_name() * src/objectidtoname.c: New file.
* 2003-08-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-08-141-1/+1
| | | | | | | | | | | PR 408/filesystem * score/Makefile.am, score/include/rtems/score/thread.h: Added sync() service. As part of adding this service, the new RTEMS service rtems_iterate_over_all_threads() was also added. This new service makes it easier to iterate over all the tasks/threads in a system and perform an action on them. * score/src/iterateoverthreads.c: New file. * ChangeLog: Fixed screwup.
* 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-121-1/+0
| | | | Makefile.am: Don't create $ARCH.
* 2002-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-091-1/+1
| | | | Makefile.am: Fix macro-file installation.
* 2002-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-091-2/+2
| | | | Makefile.am: Move include/rtems/score/cpuopts.h to STD_H_FILES.
* 2002-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-091-1/+180
| | | | | | | | * include/Makefile.am: Remove. * inline/Makefile.am: Remove. * macros/Makefile.am: Remove. * src/Makefile.am: Remove. * Makefile.am: Merge-in removed Makefile.ams.
* 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-171-2/+2
| | | | * Include $(top_srcdir)/automake/*.am.
| | | | | | | | | * cpu/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * inline/Makefile.am: Remove AUTOMAKE_OPTIONS. * macros/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-161-1/+1
| | | | | | | | | | | | | * include/rtems/Makefile.am: Remove. * include/rtems/Makefile.am: Remove. * include/Makefile.am: Handle subdirs, require automake-1.5. * macros/rtems/Makefile.am: Remove. * macros/rtems/score/Makefile.am: Remove. * macros/Makefile.am: Handle subdirs, require automake-1.5. * inline/rtems/Makefile.am: Remove. * inline/rtems/score/Makefile.am: Remove. * inline/Makefile.am: Handle subdirs, require automake-1.5. * Makefile.am: require automake-1.5
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bugJoel Sherrill1999-10-041-3/+3
* Applied patch rtems-rc-19990820-6.diff.gz fromJoel Sherrill1999-09-071-0/+10
Ralf Corsepius <corsepiu@faw.uni-ulm.de> which converted many Makefile.in's to Makefile.am's. This added a lot of files.
