* | Update company name | Sebastian Huber | 2023-05-20 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | cpukit/: Scripted embedded brains header file clean up | Joel Sherrill | 2022-03-10 | 1 | -6/+0 |
| | | | | Updates #4625. | ||||
* | sapi/src/*.c: Change license to BSD-2 | Joel Sherrill | 2022-02-28 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | sapi: Canonicalize @defgroup and @file comments | Sebastian Huber | 2020-12-02 | 1 | -2/+3 |
| | | | | | | | Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group and file brief descriptions. Update #3706. | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | 2010-08-24 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-08-24 | 1 | -0/+55 |
PR 1673/cpukit * sapi/src/chainappendnotify.c, sapi/src/chaingetnotify.c, sapi/src/chaingetwait.c, sapi/src/chainprependnotify.c: New files. * sapi/Makefile.am: Reflect changes above. * sapi/include/rtems/chain.h: Declare rtems_chain_append_with_notification(), rtems_chain_prepend_with_notification(), rtems_chain_get_with_notification(), and rtems_chain_get_with_wait(). * sapi/inline/rtems/chain.inl: Define rtems_chain_append_with_empty_check(), rtems_chain_prepend_with_empty_check(), and rtems_chain_get_with_empty_check(). |
