path: root/cpukit/rtems/src (follow)
* rtems: Initialize count of postponed jobsSebastian Huber2021-09-091-0/+1
| | | | | | | | | The rtems_rate_monotonic_get_status() directive returns an arbitrary number for the count of postponed jobs if it is called for a newly created period object. Set the count of postponed jobs to zero during object creation. Close #4511.
* score: Change TOD_LATEST_YEAR to 2099Sebastian Huber2021-09-063-39/+18
| | | | | | | | This simplifies the implementation a bit. Declare _TOD_Days_to_date[] in <rtems/score/todimpl.h>. Make _TOD_Days_per_month[] and _TOD_Days_since_last_leap_year[] static. Update #4338.
* score: Simplify _TOD_Validate()Sebastian Huber2021-09-061-9/+25
| | | | Split up the multi line if statement into smaller parts.
* rtems: Fix partitions with RTEMS_MULIPROCESSINGSebastian Huber2021-08-311-1/+1
| | | | Replace call to removed _Partition_Free() with a call to _Objects_Free().
* score: Replace priority prepend it with an enumSebastian Huber2021-08-121-1/+1
| | | | | | | | Use the new Priority_Group_order enum instead of a boolean to indicated if a priority should be inserted as the first or last node into its priority group. This makes the code more expressive. It is also a bit more efficient since a branch in _Scheduler_Node_set_priority() is avoided and a simple bitwise or operation can be used.
* rtems: Fix rtems_partition_return_buffer()Sebastian Huber2021-08-122-9/+16
| | | | | | | | The rtems_partition_return_buffer() wrongly accepted which were exactly at the buffer area end. Use the buffer area limit address for the range checking. Close #4490.
* score: Simplify calling _Thread_Exit()Sebastian Huber2021-05-262-25/+2
| | | | | Move common code into _Thread_Exit(). This enables a tail call optimization in most cases.
* rtems: Return RTEMS_CALLED_FROM_ISRSebastian Huber2021-05-261-5/+15
| | | | | | | If rtems_task_delete() is called from within interrupt context, then return RTEMS_CALLED_FROM_ISR. This makes the behaviour predictable. Update #4414.
* rtems: Fix task restart within interrupt contextSebastian Huber2021-05-141-7/+1
| | | | | | | | | | | rtems_task_restart() may be called from within interrupt context. So checking only that the thread to restart is equal to the executing thread is insufficient to determine a self restart. We have to also check that no ISR is in progress. Merge _Thread_Restart_other() and _Thread_Restart_self() into one _Thread_Restart() since they share a lot of common code. Close #4412.
* score: Return status in _Thread_Restart_other()Sebastian Huber2021-05-141-3/+4
| | | | This simplifies rtems_task_restart().
* rtems: Check entry point in rtems_task_start()Sebastian Huber2021-05-141-0/+4
| | | | Close #4410.
* rtems: Add TOD_Ticks_validationSebastian Huber2021-05-141-3/+5
| | | | | | Replace defines with an enum. Update #4406.
* rtems: Constify rtems_task_wake_when()Sebastian Huber2021-05-124-10/+7
| | | | | | | | | | | | | | | | Add a parameter to _TOD_Validate() to disable the validation of the ticks member. There are two reasons for this change. Firstly, in rtems_task_wake_when() was a double check for time_buffer == NULL (one in rtems_task_wake_when() and one in _TOD_Validate()). Secondly, the ticks member is ignored by rtems_task_wake_when(). This was done with a write of zero to the ticks member and thus a modification of the user-provided structure. Now the structure is no longer modified. Using a mask parameter is quite efficient. You just have to load an immediate value and there are no additional branches in _TOD_Validate(). Close #4406.
* rtems: Use rtems_clock_get_ticks_per_second()Sebastian Huber2021-05-121-2/+2
| | | | This avoids an integer division at runtime.
* _TOD_Validate(): Fix incorrect return codeFrank Kühndel2021-05-124-33/+44
| | | | | | | | | | | | | | | This patch fixes bug #4403. Directives * rtems_timer_fire_when() * rtems_timer_server_fire_when() * rtems_task_wake_when() are documented to return RTEMS_INVALID_ADDRESS when their time-of-day argument is NULL. But actually they return RTEMS_INVALID_CLOCK. To fix the issue this patch changes _TOD_Validate() to return a status code instead of just true/false. Close #4403
* rtems: Use _Objects_Free_nothing() for msg queuesSebastian Huber2021-05-111-1/+6
| | | | | | | | Use _Objects_Free_nothing() for rtems_message_queue_construct() to avoid unreachable code in _CORE_message_queue_Close() in case only user-provided message buffers are used. Update #4007.
* score: Rename _Stack_Free_nothing()Sebastian Huber2021-05-111-1/+1
| | | | | | | Rename _Stack_Free_nothing() in _Objects_Free_nothing() to make it reusable for the message queue buffers. Update #4007.
* rtems: rtems_scheduler_get_processor_set() statusSebastian Huber2021-05-061-1/+1
| | | | | | | | | In case the processor set is not large enough to contain the processor set owned by the scheduler return RTEMS_INVALID_SIZE instead of RTEMS_INVALID_NUMBER. This is more in line with other directives since the issue is related to the size of an object. Close #4401.
* rtems: rtems_scheduler_ident_by_processor_set()Sebastian Huber2021-05-061-0/+4
| | | | Check for a NULL processor set pointer.
* rtems: Use allocator mutex for timer serverSebastian Huber2021-05-041-4/+2
| | | | | | | The allocator mutex is recursive and already used for the task creation in rtems_timer_initiate_server(). Just use this mutex instead of the once mutex to serialize the initialization. This avoids a dependency on condition variables which are not used here.
* score: Add _Thread_Dispatch_direct_no_return()Sebastian Huber2021-05-021-1/+1
| | | | | | | | | | The __builtin_unreachable() cannot be used with current GCC versions to tell the compiler that a function does not return to the caller, see: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=99151 Add a no return variant of _Thread_Dispatch_direct() to avoid generation of dead code.
* Use alias for rtems_task_self() and pthread_self()Sebastian Huber2021-04-301-28/+0
| | | | This may reduce the code size a bit.
* Return status code for _Thread_Start()Sebastian Huber2021-04-271-3/+4
| | | | | This avoids having conditional statements to get the API-specific status code.
* Return status code for _Scheduler_Set_affinity()Sebastian Huber2021-04-271-3/+4
* Simplify get affinitiy directivesSebastian Huber2021-04-271-3/+0
| | | | | There is no need to disable thread dispatching to get the affinity of a task.
* Return status code for _Scheduler_Get_affinity()Sebastian Huber2021-04-271-3/+4
* rtems: Constify timer fire when directivesSebastian Huber2021-04-272-2/+2
| | | | Close #4392.
* rtems: Check for NULL config in task constructSebastian Huber2021-04-231-0/+4
| | | | | | | Since there are already excessive NULL pointer checks in the Classic API, do this also in rtems_task_construct(). Update #3959.
* rtems: Check for NULL config in msgq constructSebastian Huber2021-04-231-0/+4
| | | | | | | Since there are already excessive NULL pointer checks in the Classic API, do this also in rtems_message_queue_construct(). Update #4007.
* clock:_TOD_To_seconds(): Fix year 2514 overflowFrank Kühndel2021-04-212-1/+2
| | | | | | | | | | | | | | | | | | | | | | | This patch fixes issue #4338 by changing _TOD_Validate() to only accept years till 2105. This requires another patch to change the documentation of rtems_clock_set() and other affected API functions (indicating the end date is 2105 not 2514). I tried to support till year 2514 but it turned out that this needs changing the Timer Manager too. That in turn would mean to change _TOD_Seconds_since_epoch( void ) from 32 to 64 bit. Sebastian pointed out that a naive extension leads to trouble with 32 bit processors. He deemed a safe re-implementation too costly performance wise considering that year 2106 is far away and current binaries using RTEMS Classic API are unlikely to be in use by 2106. The constant TOD_SECONDS_AT_2100_03_01_00_00 in cpukit/rtems/src/clocktodtoseconds.c happens to be wrong by 1 hour. When setting the date 2100-Feb-28 23:59:59 and then reading the date again you will find yourself in 2100-Feb-27. Update #4338
* score: Replace Objects_Name_or_id_lookup_errorsSebastian Huber2021-04-074-36/+9
| | | | | Replace Objects_Name_or_id_lookup_errors with new Status_Control codes. Get rid of the _Status_Object_name_errors_to_status lookup table.
* score: Fix internal error status numberSebastian Huber2021-04-071-0/+22
| | | | | | The value of STATUS_CLASSIC_INTERNAL_ERROR must be equal to RTEMS_INTERNAL_ERROR. Add static assertions to ensure that the status codes match.
* rtems: Relax mode checks in rtems_signal_catch()Sebastian Huber2021-03-191-2/+8
| | | | | | | | Check only for invalid modes if a valid handler is presented to rtems_signal_catch(). When NULL is used for the handler, ASR processing is disabled and the mode is not used. Update #4244.
* rtems: Fix rtems_task_mode()Sebastian Huber2021-03-181-16/+22
| | | | | | Do the ASR and preemption mode change only if requested by the mode mask. The bug was introduced by 508f868237225a75e566d9fd304206363cfe441d.
* rtems: Improve semaphore create error checksSebastian Huber2021-03-161-6/+4
| | | | | | Do not mix checks for different error indicators (RTEMS_NOT_DEFINED and RTEMS_INVALID_NUMBER). This simplifies the specification of rtems_semaphore_create().
* rtems: Require RTEMS_PRIORITY for MrsP semaphoresSebastian Huber2021-03-161-2/+2
| | | | | | | | | MrsP semaphores are a generalization of the priority ceiling semaphores for SMP configurations. Priority ceiling semaphores are required to use the priority task wait queue discipline. Require this discipline also for MrsP semaphores. Close #4347.
* rtems: Simplify rtems_signal_catch()Sebastian Huber2021-03-021-1/+19
| | | | | In uniprocessor configurations, we can simplify rtems_signal_catch(). Add a validation test for the SMP special case.
* rtems: Simplify _Signal_Action_handler()Sebastian Huber2021-03-021-8/+3
| | | | | Use the invariant that an ASR is only processed if ASR processing is enabled.
* score: Fix thread initializationSebastian Huber2021-02-261-16/+7
| | | | | | | | Close the thread object if a thread create extension fails. Also call the delete extension to avoid resource leaks in early extensions if a late extension fails. Close #4270.
* score: Simplify core barrierSebastian Huber2021-02-241-14/+15
| | | | | | Use the number of threads which must arrive at the barrier to trip the automatic release also to indicate if the barrier is a manual release barrier.
* score: Remove _Objects_Open()Sebastian Huber2021-02-249-35/+16
| | | | | Use the type safe _Objects_Open_u32() instead. Return the object identifier to enforce a common usage pattern.
* rtems: Simplify rtems_task_mode()Sebastian Huber2021-02-201-32/+25
| | | | | Do the preemption and ASR processing changes in one rush and acquire the thread state lock only once.
* rtems: Avoid potential recursion in ASR handlingSebastian Huber2021-02-201-7/+91
| | | | | | | | Do the mode changes necessary for the ASR processing directly under protection of the thread state lock to avoid the recursive calls to thread dispatching done in rtems_task_mode(). Close #4244.
* rtems: Add _Modes_Apply_timeslice_to_thread()Sebastian Huber2021-02-201-8/+2
| | | | Update #4244.
* rtems: New errors for rtems_signal_catch()Sebastian Huber2021-02-202-10/+19
| | | | | | Ensure that no invalid modes are set during ASR processing. Update #4244.
* rtems: Remove _Modes_Set_interrupt_level()Sebastian Huber2021-02-201-5/+3
| | | | | | This call just obfuscated the call to _ISR_Set_level(). Update #4244.
* rtems: Simplify signal handlingSebastian Huber2021-02-203-32/+33
| | | | | | | Remove superfluous ASR_Information::signals_posted. Move code out of trivial inline functions. Update #4244.
* rtems: Move _Signal_Action_handler()Sebastian Huber2021-02-202-54/+54
| | | | | | | | Move _Signal_Action_handler() and signal MP initialization to rtems_signal_send(). The goal is to make _Signal_Action_handler() a static function in a follow up patch. Update #4244.
* rtems: Remove unused ASR_Information::nest_levelSebastian Huber2021-02-201-2/+0
| | | | Update #4244.
* score: Change thread action lockingSebastian Huber2021-02-201-2/+4
| | | | | | | | Require that the corresponding lock is acquired before the action handler returns. This helps to avoid recursion in the signal processing. Update #4244.
