line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3070.
Update #3069.
Cast the internal PRIORITY_MAXIMUM to the right type for a Classic API
task priority to avoid integer conversion warnings.
Update #2797.
Avoid dead code in non-SMP configurations. Return scheduler identifier
independent of the current processor count of the scheduler via
rtems_scheduler_ident(), since this value may change during run-time.
Check the processor count in _Scheduler_Set() under scheduler lock
protection.
Update #2797.
Update #2423.
Update #2556.
Update #2784.
Task priorities are only valid within a scheduler instance. The
rtems_task_set_scheduler() directive moves a task from one scheduler
instance to another using the current priority of the thread. However,
the current task priority of the source scheduler instance is undefined
in the target scheduler instance. Add a third parameter to specify the
priority.
Close #2749.
A 32-bit Priority_Control limits the uptime to 49 days with a 1ms clock
tick in case the EDF scheduler is used. Increase it to 64-bit to enable
proper operation of the EDF scheduler,
Close 2173.
The priority values are only valid within a scheduler instance. Thus,
the maximum priority value must be defined per scheduler instance. The
first scheduler instance defines PRIORITY_MAXIMUM. This implies that
RTEMS_MAXIMUM_PRIORITY and POSIX_SCHEDULER_MAXIMUM_PRIORITY are only
valid for threads of the first scheduler instance. Further
API/implementation changes are necessary to fix this.
Update #2556.
Update #2494.
Update #2555.
Update #2408.
Notepads where a feature of RTEMS' tasks that simply functioned in
the same way as POSIX keys or threaded local storage (TLS). They were
introduced well before per task variables, which are also deprecated,
and were barely used in favor of their POSIX alternatives.
In addition to their scarce usage, Notepads took up unnecessary memory.
For each task:
- 16 32-bit integers were allocated.
- A total of 64 bytes per task per thread.
This is especially critical in low memory and safety-critical applications.
They are also defined as uint32_t, and therefore are not guaranteed to
hold a pointer.
Lastly, they are not portable solutions for SMP and uniprocessor systems,
like POSIX keys and TLS.
updates #2493.
Deprecate Classic API Notepads. Mark task_set/get_note() with
the deprecated attribute, and also mark the notepads field.
Replace disable with enable option for notepads in confdefs.h,
and make notepads disabled by default. The previous option
CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS is now unused and
will emit a compile-time warning. A new option
CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS is available to turn
on notepads, but it also will emit a compile-time warning
to indicate that notepads are deprecated.
Closes #2265
Do not change the scheduler with this function. Documentation. Coding
style.
The current implementation of task migration in RTEMS has some
implications with respect to the interrupt latency. It is crucial to
preserve the system invariant that a task can execute on at most one
processor in the system at a time. This is accomplished with a boolean
indicator in the task context. The processor architecture specific
low-level task context switch code will mark that a task context is no
longer executing and waits that the heir context stopped execution
before it restores the heir context and resumes execution of the heir
task. So there is one point in time in which a processor is without a
task. This is essential to avoid cyclic dependencies in case multiple
tasks migrate at once. Otherwise some supervising entity is necessary to
prevent life-locks. Such a global supervisor would lead to scalability
problems so this approach is not used. Currently the thread dispatch is
performed with interrupts disabled. So in case the heir task is
currently executing on another processor then this prolongs the time of
disabled interrupts since one processor has to wait for another
processor to make progress.
It is difficult to avoid this issue with the interrupt latency since
interrupts normally store the context of the interrupted task on its
stack. In case a task is marked as not executing we must not use its
task stack to store such an interrupt context. We cannot use the heir
stack before it stopped execution on another processor. So if we enable
interrupts during this transition we have to provide an alternative task
independent stack for this time frame. This issue needs further
investigation.
Avoid the SMP_FATAL_SCHEDULER_WITHOUT_PROCESSORS fatal error and make it
a run-time error in rtems_scheduler_ident() and _Scheduler_Get_by_id().
Make rtems_task_get_affinity() and rtems_task_set_affinity() available
on non-SMP configurations. Allow larger CPU sets.
The thread control block contains fields that point to application
configuration dependent memory areas, like the scheduler information,
the API control blocks, the user extension context table, the RTEMS
notepads and the Newlib re-entrancy support. Account for these areas in
the configuration and avoid extra workspace allocations for these areas.
This helps also to avoid heap fragementation and reduces the per thread
memory due to a reduced heap allocation overhead.
Per task variables are inherently unsafe in SMP systems. This
patch disables them from the build and adds warnings in the
appropriate documentation and configuration sections.
Add the following methods:
+ rtems_task_get_affinity
+ rtems_task_set_affinity
Move implementation specific parts of states.h and states.inl into new
header file statesimpl.h. The states.h contains now only the
application visible API.
Move implementation specific parts of tasks.h and tasks.inl into new
header file tasksimpl.h. The tasks.h contains now only the application
visible API.
http://www.google-melange.com/gci/task/view/google/gci2012/8024203
http://www.google-melange.com/gci/task/view/google/gci2012/8015207
http://www.google-melange.com/gci/task/view/google/gci2012/7950206
http://www.google-melange.com/gci/task/view/google/gci2012/8019205
http://www.google-melange.com/gci/task/view/google/gci2012/7950205
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/8025204
http://www.google-melange.com/gci/task/view/google/gci2012/8025203
System events are similar to normal events. They offer a second set of
events. These events are intended for internal RTEMS use and should not
be used by applications (with the exception of the transient system
event).
Change event implementation to enable reuse for system events.
