* | cpukit/posix/src/[p-z]*.c: Change license to BSD-2 | Joel Sherrill | 2022-02-28 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | Include missing <string.h> | Sebastian Huber | 2017-08-25 | 1 | -0/+1 |
| | | | | Update #2133. | ||||
* | posix: fix warnings with mmap from heap/wkspace | Gedare Bloom | 2017-07-24 | 1 | -1/+1 |
| | | | | | | Avoid void pointer arithmetic. Updates #2859. | ||||
* | posix/mman: add mmap support for shm objects | Gedare Bloom | 2017-05-05 | 1 | -0/+20 |
| | | | | Update #2859. | ||||
* | posix: shared memory support | Gedare Bloom | 2017-01-13 | 1 | -0/+90 |
Add POSIX shared memory manager (Shm). Includes a hook-based approach for the backing memory storage that defaults to the Workspace, and a test is provided using the heap. A test is also provided for the basic use of mmap'ing a shared memory object. This test currently fails at the mmap stage due to no support for mmap. |
