Updates #3053.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
This function is useful for operations which synchronously block, e.g.
self restart, self deletion, yield, sleep. It helps to detect if these
operations are called in the wrong context. Since the thread dispatch
necessary indicator is not used, this is more robust in some SMP
situations.
Update #2751.
Update #2555.
The _Scheduler_Yield() was called by the executing thread with thread
dispatching disabled and interrupts enabled. The rtems_task_suspend()
is explicitly allowed in ISRs:
http://rtems.org/onlinedocs/doc-current/share/rtems/html/c_user/Interrupt-Manager-Directives-Allowed-from-an-ISR.html#Interrupt-Manager-Directives-Allowed-from-an-ISR
Unlike the other scheduler operations the locking was performed inside
the operation. This lead to the following race condition. Suppose a
ISR suspends the executing thread right before the yield scheduler
operation. Now the executing thread is not longer in the set of ready
threads. The typical scheduler operations did not check the thread
state and will now extract the thread again and enqueue it. This
corrupted data structures.
Add _Thread_Yield() and do the scheduler yield operation with interrupts
disabled. This has a negligible effect on the interrupt latency.
Scheduler operations must be free of a global scheduler context to
enable partitioned/clustered scheduling.
Move implementation specific parts of scheduler.h and scheduler.inl into
new header file schedulerimpl.h. The scheduler.h contains now only the
application visible API.
Move implementation specific parts of priority.h and priority.inl into
new header file priorityimpl.h. Remove priority.h since there is no
The yielding thread of the yield operation is now specified by a
parameter. The tick operation may be performed for each executing
thread in a SMP configuration.
http://www.google-melange.com/gci/task/view/google/gci2012/7958218
PR 1647/cpukit
* posix/src/nanosleep.c, posix/src/sched_yield.c,
rtems/src/taskwakeafter.c, sapi/include/confdefs.h,
sapi/include/rtems/config.h, sapi/src/exinit.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/prioritybitmap.h,
score/inline/rtems/score/thread.inl, score/src/thread.c,
score/src/threadchangepriority.c, score/src/threadclearstate.c,
score/src/threadclose.c, score/src/threadinitialize.c,
score/src/threadready.c, score/src/threadresume.c,
score/src/threadsetpriority.c, score/src/threadsetstate.c,
score/src/threadsettransient.c, score/src/threadsuspend.c,
score/src/threadtickletimeslice.c: Refactor scheduler out of thread
handler to facilitate alternate scheduler implementations.
* score/src/threadyieldprocessor.c: Removed.
* score/src/schedulerprioritythreadschedulerupdate.c,
score/src/schedulerprioritythreadschedulerfree.c,
score/src/schedulerpriorityblock.c, score/src/scheduler.c,
score/src/schedulerprioritythreadschedulerallocate.c,
score/src/schedulerpriorityunblock.c,
score/src/schedulerpriority.c, score/src/schedulerpriorityyield.c,
score/include/rtems/score/schedulerpriority.h,
score/include/rtems/score/scheduler.h,
score/inline/rtems/score/scheduler.inl,
score/inline/rtems/score/schedulerpriority.inl: New files.
* posix/Makefile.am, posix/src/clockgetcpuclockid.c,
posix/src/clockgetenableattr.c, posix/src/clockgettime.c,
posix/src/devctl.c, posix/src/execl.c, posix/src/execle.c,
posix/src/execlp.c, posix/src/execv.c, posix/src/execve.c,
posix/src/execvp.c, posix/src/fork.c, posix/src/mutexinit.c,
posix/src/pthreadatfork.c, posix/src/pthreadgetcpuclockid.c,
posix/src/pthreadkill.c, posix/src/semaphorecreatesupp.c,
posix/src/sysconf.c, posix/src/wait.c, posix/src/waitpid.c: Split
files into one function per file.
* posix/src/aio_cancel.c, posix/src/aio_error.c, posix/src/aio_fsync.c,
posix/src/aio_read.c, posix/src/aio_return.c,
posix/src/aio_suspend.c, posix/src/aio_write.c,
posix/src/lio_listio.c, posix/src/sched_getparam.c,
posix/src/sched_getprioritymax.c, posix/src/sched_getprioritymin.c,
posix/src/sched_getscheduler.c, posix/src/sched_rr_get_interval.c,
posix/src/sched_setparam.c, posix/src/sched_setscheduler.c,
posix/src/sched_yield.c: New files.
* posix/src/aio.c, posix/src/sched.c, posix/src/types.c: Removed.
