Updates #3053.
This avoids having conditional statements to get the API-specific status
code.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
This allows to use header includes in "config.h" to reduce the build
configuration checks.
Update #3818.
Use Processor_mask instead.
Update #2514.
Return stack area via pthread_getattr_np().
Simplify
* pthread_attr_setaffinity_np(), and
* pthread_attr_getaffinity_np()
and let the scheduler do the more sophisticated error checks.
Make
* pthread_setaffinity_np(),
* pthread_getaffinity_np(),
available in all configurations.
Update #2514.
Close #3145.
Close #3168.
The original CPU_COPY() support of Newlib <sys/cpuset.h> had the
parameters in the wrong order. This is fixed in Newlib since
2017-05-22.
Update #3023.
Uniformly use *_Get() to get an object by identifier with a lock
context.
Update #2555.
Clustered/partitioned scheduling helps to control the worst-case
latencies in the system. The goal is to reduce the amount of shared
state in the system and thus prevention of lock contention. Modern
multi-processor systems tend to have several layers of data and
instruction caches. With clustered/partitioned scheduling it is
possible to honour the cache topology of a system and thus avoid
expensive cache synchronization traffic.
We have clustered scheduling in case the set of processors of a system
is partitioned into non-empty pairwise-disjoint subsets. These subsets
are called clusters. Clusters with a cardinality of one are partitions.
Each cluster is owned by exactly one scheduler instance.
Scheduler operations must be free of a global scheduler context to
enable partitioned/clustered scheduling.
This patch adds the following methods:
+ pthread_get_affinity_np
+ pthread_set_affinity_np
