Updates #3053.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
Use the Thread_Control::resource_count for the no protocol mutexes.
Merge the no protocol and priority inherit CORE mutex seize/surrender
operations.
Provide dedicated seize and surrender methods for inherit priority
mutexes. This eliminates CORE_mutex_Attributes.
Rework seize and surrender methods to use CORE_ceiling_mutex_Control.
This eliminates CORE_mutex_Disciplines.
Add CORE_recursive_mutex_Control and CORE_ceiling_mutex_Control to avoid
the run-time evaluation of attributes to figure out how a particular
mutex methods should behave. Start with the no protocol variants. This
eliminates the CORE_MUTEX_DISCIPLINES_FIFO and
CORE_MUTEX_DISCIPLINES_PRIORITY disciplines.
Unify the status codes of the Classic and POSIX API to use the new enum
Status_Control. This eliminates the Thread_Control::Wait::timeout_code
field and the timeout parameter of _Thread_queue_Enqueue_critical() and
_MPCI_Send_request_packet(). It gets rid of the status code translation
tables and instead uses simple bit operations to get the status for a
particular API. This enables translation of status code constants at
compile time. Add _Thread_Wait_get_status() to avoid direct access of
thread internal data structures.
Drop the multiprocessing (MP) dependent callout parameter from the
thread queue extract, dequeue, flush and unblock methods. Merge this
parameter with the lock context into new structure Thread_queue_Context.
This helps to gets rid of the conditionally compiled method call
helpers.
Get rid of the mp_id parameter used for some thread queue methods. Use
THREAD_QUEUE_QUEUE_TO_OBJECT() instead.
Uniformly use *_Get() to get an object by identifier with a lock
context.
Remove superfluous location parameter.
The thread queue implementation was heavily reworked to support SMP.
This broke the multiprocessing support of the thread queues. This is
fixed by this patch.
A thread proxy is unblocked due to three reasons
1) timeout,
2) request satisfaction, and
3) extraction.
In case 1) no MPCI message must be sent. This is ensured via the
_Thread_queue_MP_callout_do_nothing() callout set during
_Thread_MP_Allocate_proxy().
In case 2) and 3) an MPCI message must be sent. In case we interrupt
the blocking operation during _Thread_queue_Enqueue_critical(), then
this message must be sent by the blocking thread. For this the new
fields Thread_Proxy_control::thread_queue_callout and
Thread_Proxy_control::thread_queue_id are used.
Delete the individual API MP callout types and use
Thread_queue_MP_callout throughout. This type is only defined in
multiprocessing configurations. Prefix the multiprocessing parameters
with mp_ to ease code review. Multiprocessing specific parameters are
optional due to use of a similar macro pattern. There is no overhead
for non-multiprocessing configurations.
Rename _POSIX_Absolute_timeout_to_ticks() to
_TOD_Absolute_timeout_to_ticks() and move it to the score directory.
Delete empty <rtems/posix/time.h>.
Update #2273.
Move implementation specific parts of mpci.h into new header file
mpciimpl.h. The mpci.h contains now only the application visible API.
Move implementation specific parts of priority.h and priority.inl into
new header file priorityimpl.h. Remove priority.h since there is no
Move implementation specific parts of coremutex.h and coremutex.inl into
new header file coremuteximpl.h. The coremutex.h contains now only the
Move implementation specific parts of mutex.h and mutex.inl into new
header file muteximpl.h. The mutex.h contains now only the application
visible API.
Add and use _Objects_Put_without_thread_dispatch(). These two functions
pair with the _Objects_Get() function. This helps to introduce object
specific SMP locks to avoid lock contention.
http://www.google-melange.com/gci/task/view/google/gci2012/7958218
* posix/preinstall.am, posix/include/aio.h, posix/include/devctl.h,
posix/include/mqueue.h, posix/include/sched.h,
posix/include/semaphore.h, posix/include/rtems/posix/cancel.h,
posix/include/rtems/posix/timer.h,
posix/src/cancel.c, posix/src/cancelrun.c, posix/src/cleanuppop.c,
posix/src/cleanuppush.c, posix/src/cond.c,
posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c,
posix/src/condattrinit.c, posix/src/condattrsetpshared.c,
posix/src/condbroadcast.c, posix/src/conddefaultattributes.c,
posix/src/conddestroy.c, posix/src/condinit.c,
posix/src/condsignal.c, posix/src/condsignalsupp.c,
posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/key.c,
posix/src/keycreate.c, posix/src/keydelete.c,
posix/src/keysetspecific.c, posix/src/mqueue.c,
posix/src/mqueueclose.c, posix/src/mqueuecreatesupp.c,
posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c,
posix/src/mqueuenametoid.c, posix/src/mqueuenotify.c,
posix/src/mqueueopen.c, posix/src/mqueuereceive.c,
posix/src/mqueuerecvsupp.c, posix/src/mqueuesend.c,
posix/src/mqueueunlink.c, posix/src/mutex.c,
posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c,
posix/src/mutexdefaultattributes.c, posix/src/mutexdestroy.c,
posix/src/mutexgetprioceiling.c, posix/src/mutexlock.c,
posix/src/mutextrylock.c, posix/src/mutexunlock.c,
posix/src/psignal.c, posix/src/psignalchecksignal.c,
posix/src/psignalunblockthread.c, posix/src/ptimer.c,
posix/src/sempost.c, posix/src/semtrywait.c, posix/src/semunlink.c,
posix/src/semwait.c, posix/src/setcancelstate.c,
posix/src/setcanceltype.c, posix/src/sysconf.c,
posix/src/testcancel.c: Add missing copyright statements.
* libcsupport/src/malloc.c, libmisc/monitor/mon-command.c,
posix/preinstall.am, posix/include/rtems/posix/cond.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/semaphore.h, posix/src/conddestroy.c,
posix/src/mutexdestroy.c, posix/src/mutexinit.c,
posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c,
sapi/include/confdefs.h, sapi/include/rtems/config.h,
sapi/include/rtems/init.h, sapi/include/rtems/sptables.h,
sapi/src/exinit.c, score/include/rtems/system.h,
score/include/rtems/score/mpci.h, score/src/mpci.c,
score/src/thread.c, score/src/threadcreateidle.c,
score/src/threadstackallocate.c, score/src/threadstackfree.c,
score/src/wkspace.c: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/semaphore.h, posix/src/cancel.c,
posix/src/conddestroy.c, posix/src/condsignalsupp.c,
posix/src/condwaitsupp.c, posix/src/keydelete.c,
posix/src/keygetspecific.c, posix/src/keysetspecific.c,
posix/src/mqueueclose.c, posix/src/mqueuegetattr.c,
posix/src/mqueuetranslatereturncode.c, posix/src/mutexdestroy.c,
posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c,
posix/src/mutexunlock.c, posix/src/pbarrierdestroy.c,
posix/src/pbarriertranslatereturncode.c, posix/src/pbarrierwait.c,
posix/src/prwlockdestroy.c, posix/src/prwlockrdlock.c,
posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c,
posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c,
posix/src/prwlockwrlock.c, posix/src/pspindestroy.c,
posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c,
posix/src/pspintrylock.c, posix/src/pspinunlock.c,
posix/src/pthreaddetach.c, posix/src/pthreadequal.c,
posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c,
posix/src/pthreadkill.c, posix/src/pthreadsetschedparam.c,
posix/src/ptimer1.c, posix/src/semaphorewaitsupp.c,
posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/types.c,
rtems/src/msgqtranslatereturncode.c, rtems/src/semobtain.c,
rtems/src/timerfireafter.c, score/include/rtems/system.h,
score/include/rtems/score/coresem.h: Restructed to move the
OBJECTS_LOCAL case to the top of the switch statement and
eliminate the fall-through return of POSIX_BOTTOM_REACHED. These
changes produced simplier assembly code and allowed for complete
test coverage. Also applied some consistency to the functions
that translate the core status codes to POSIX status codes.
* posix/src/mutextranslatereturncode.c,
posix/src/semaphoretranslatereturncode.c: New files.
* posix/src/mutexfromcorestatus.c: Removed.
* posix/Makefile.am, posix/preinstall.am, posix/src/cancel.c,
posix/src/condsignalsupp.c, posix/src/condwaitsupp.c,
posix/src/mqueueunlink.c, posix/src/mutexattrdestroy.c,
posix/src/mutexunlock.c, posix/src/semaphorecreatesupp.c,
posix/src/semaphoredeletesupp.c, posix/src/semaphorewaitsupp.c,
posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/semunlink.c,
posix/src/types.c, score/cpu/powerpc/rtems/old-exceptions/cpu.h:
Remove all pretense of POSIX MP support. The support in place was
only a shell. This should make maintenance easier.
* posix/include/rtems/posix/condmp.h,
posix/include/rtems/posix/mqueuemp.h,
posix/include/rtems/posix/mutexmp.h,
posix/include/rtems/posix/pthreadmp.h,
posix/include/rtems/posix/semaphoremp.h, posix/src/condmp.c,
posix/src/mutexmp.c, posix/src/semaphoremp.c: Removed.
* itron/src/can_wup.c, itron/src/chg_pri.c, itron/src/del_mbf.c,
itron/src/del_mbx.c, itron/src/del_sem.c, itron/src/del_tsk.c,
itron/src/frsm_tsk.c, itron/src/ref_mbf.c, itron/src/ref_mbx.c,
itron/src/ref_sem.c, itron/src/ref_tsk.c, itron/src/rel_wai.c,
itron/src/rsm_tsk.c, itron/src/sig_sem.c, itron/src/snd_mbx.c,
itron/src/sta_tsk.c, itron/src/sus_tsk.c, itron/src/ter_tsk.c,
itron/src/trcv_mbf.c, itron/src/trcv_mbx.c, itron/src/tsnd_mbf.c,
itron/src/twai_sem.c, posix/src/cancel.c, posix/src/conddestroy.c,
posix/src/condinit.c, posix/src/condsignalsupp.c,
posix/src/mutexinit.c, posix/src/mutexlocksupp.c,
posix/src/pbarrierdestroy.c, posix/src/pbarrierwait.c,
posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c,
posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c,
posix/src/pspindestroy.c, posix/src/pspinlock.c,
rtems/src/barrierdelete.c, rtems/src/barrierrelease.c,
rtems/src/barrierwait.c, rtems/src/dpmemdelete.c,
rtems/src/eventtimeout.c, rtems/src/msgqbroadcast.c,
rtems/src/msgqgetnumberpending.c, rtems/src/msgqreceive.c,
rtems/src/msgqsend.c, rtems/src/msgqurgent.c, rtems/src/partdelete.c,
rtems/src/partgetbuffer.c, rtems/src/partreturnbuffer.c,
rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c,
rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c,
rtems/src/ratemontimeout.c, rtems/src/regiondelete.c,
rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c,
rtems/src/regionreturnsegment.c, rtems/src/semdelete.c,
rtems/src/semflush.c, rtems/src/semobtain.c, rtems/src/semrelease.c,
rtems/src/signalsend.c, rtems/src/taskdelete.c,
rtems/src/taskgetnote.c, rtems/src/taskissuspended.c,
rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c,
rtems/src/taskvariableget.c, rtems/src/timercancel.c,
rtems/src/timerserverfirewhen.c, sapi/src/extensiondelete.c,
score/include/rtems/score/object.h, score/src/corerwlocktimeout.c,
score/src/mpci.c, score/src/objectgetnameasstring.c,
score/src/threaddelayended.c, score/src/threadqtimeout.c: When
multiprocessing is disabled, do not even allow the constant
OBJECTS_REMOTE to appear in the source. Even at -O2, the presence of
a case OBJECTS_REMOTE in each id->pointer _Objects_Get switch results
in the generation of binary code which can NOT be reached.
PR 1231/cpukit
* posix/src/adasupp.c, posix/src/clockgetcpuclockid.c,
posix/src/clockgetenableattr.c, posix/src/clockgetres.c,
posix/src/clockgettime.c, posix/src/clocksetenableattr.c,
posix/src/mutexlocksupp.c, posix/src/mutexmp.c,
posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c,
posix/src/nanosleep.c, posix/src/posixintervaltotimespec.c,
posix/src/posixtimespecsubtract.c,
posix/src/posixtimespectointerval.c,
posix/src/ptimer1.c, posix/src/sched.c, posix/src/time.c: Remove
unneeded includes of assert.h
