PR 449/rtems:
* src/getegid.c: Remove (Moved to ../libcsupport/src).
* src/geteuid.c: Remove (Moved to ../libcsupport/src).
* src/getgid.c: Remove (Moved to ../libcsupport/src).
* src/getgroups.c: Remove (Moved to ../libcsupport/src).
* src/getlogin.c: Remove (Moved to ../libcsupport/src).
* src/getpgrp.c: Remove (Moved to ../libcsupport/src).
* src/getpid.c: Remove (Moved to ../libcsupport/src).
* src/getppid.c: Remove (Moved to ../libcsupport/src).
* src/getuid.c: Remove (Moved to ../libcsupport/src).
* src/setpgid.c: Remove (Moved to ../libcsupport/src).
* src/setsid.c: Remove (Moved to ../libcsupport/src).
* Makefile.am: Reflect changes above
all APIs.
PROBLEMS
can/will be fixed.
cxe1001 of the ACVC 2.0.1. This allows gnat/rtems to pass the partition
tests.
