Add Thread_Life_state::THREAD_LIFE_CHANGE_DEFERRED and rework the POSIX
thread cancellation to use the thread life states.
Update #2555.
Update #2626.
Move implementation specific parts of pthread.h and pthread.inl into new
header file pthreadimpl.h. The pthread.h contains now only the
application visible API.
Add and use _Objects_Put_without_thread_dispatch(). These two functions
pair with the _Objects_Get() function. This helps to introduce object
specific SMP locks to avoid lock contention.
http://www.google-melange.com/gci/task/view/google/gci2012/7997223
* posix/include/rtems/posix/threadsup.h, posix/src/cancel.c,
posix/src/canceleval.c: Make psxcancel run again.
_POSIX_Thread_Exit() can be called on running thread or another
thread when it is cancelled.
* posix/include/rtems/posix/cancel.h, posix/src/cancel.c,
posix/src/canceleval.c, posix/src/setcancelstate.c,
posix/src/setcanceltype.c: Fix a minor bug in the previous
modification which resulted in psxcancel failing.
* posix/Makefile.am, posix/include/rtems/posix/cancel.h,
posix/src/cancel.c, posix/src/setcancelstate.c,
posix/src/setcanceltype.c: Add
_POSIX_Thread_Evaluate_cancellation_and_enable_dispatch method to
avoid duplication of code and ease coverage analysis.
* posix/src/canceleval.c: New file.
