path: root/cpukit/posix/inline/rtems/posix/cond.inl (follow)
* posix: Create condition variable impl headerSebastian Huber2013-07-221-64/+0
| | | | | | Move implementation specific parts of cond.h and cond.inl into new header file condimpl.h. The cond.h contains now only the application visible API.
* 2011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-07-241-6/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script.
* 2011-06-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-06-241-6/+5
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h, include/rtems/pci.h, include/rtems/userenv.h, libblock/include/rtems/flashdisk.h, libblock/include/rtems/nvdisk-sram.h, libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h, libcsupport/include/console.h, libcsupport/include/iosupp.h, libcsupport/include/spurious.h, libcsupport/include/motorola/mc68230.h, libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h, libcsupport/include/rtems/framebuffer.h, libcsupport/include/rtems/gxx_wrappers.h, libcsupport/include/rtems/libcsupport.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/malloc.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h, libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h, libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h, libmisc/capture/capture-cli.h, libmisc/capture/capture.h, libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h, libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h, libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h, libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h, libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h, posix/include/mqueue.h, posix/include/semaphore.h, posix/include/rtems/posix/aio_misc.h, posix/include/rtems/posix/barrier.h, posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h, posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/posixapi.h, posix/include/rtems/posix/priority.h, posix/include/rtems/posix/psignal.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/ptimer.h, posix/include/rtems/posix/rwlock.h, posix/include/rtems/posix/semaphore.h, posix/include/rtems/posix/sigset.h, posix/include/rtems/posix/spinlock.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/time.h, posix/include/rtems/posix/timer.h, posix/inline/rtems/posix/barrier.inl, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/priority.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/rwlock.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/spinlock.inl, posix/inline/rtems/posix/timer.inl, rtems/mainpage.h, rtems/include/rtems/rtems/barrier.h, rtems/include/rtems/rtems/object.h, rtems/include/rtems/rtems/timer.h, rtems/inline/rtems/rtems/barrier.inl, rtems/inline/rtems/rtems/timer.inl, rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h, sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h, score/include/rtems/score/object.h, score/include/rtems/score/priority.h, score/inline/rtems/score/object.inl, score/inline/rtems/score/priority.inl: Add @file Doxygen directives and descriptions to files which originated with RTEMS. This improves the file list page generated by Doxygen.
* Convert to "bool".Ralf Corsepius2008-09-041-1/+1
* Add header guard to force indirect inclusion.Ralf Corsepius2008-08-191-0/+4
* 2008-01-09 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-01-091-39/+0
| | | | | | | | | | | * posix/Makefile.am, posix/include/rtems/posix/cond.h, posix/include/rtems/posix/mutex.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mutex.inl: Do not include POSIX Mutex or Condition Variable object get helpers because they are more complicated than the norm. They can implicitly perform a create. They cross the line as being too complex and large to inline since they negatively impact size and binary test coverage. * posix/src/condget.c, posix/src/mutexget.c: New files.
* 2006-02-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-02-011-1/+2
| | | | | * posix/inline/rtems/posix/cond.inl, posix/macros/rtems/posix/cond.inl, posix/src/conddestroy.c: Remove warnings.
* Keep compiler happy by making some casts explicit. (PR859)Eric Norum2006-01-151-1/+1
* New header guards.Ralf Corsepius2005-02-211-2/+2
* Add doxygen preamble.Ralf Corsepius2004-11-211-0/+4
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/posix/cond.h, include/rtems/posix/condmp.h, include/rtems/posix/config.h, include/rtems/posix/intr.h, include/rtems/posix/key.h, include/rtems/posix/mqueue.h, include/rtems/posix/mqueuemp.h, include/rtems/posix/mutex.h, include/rtems/posix/mutexmp.h, include/rtems/posix/posixapi.h, include/rtems/posix/pthread.h, include/rtems/posix/pthreadmp.h, include/rtems/posix/ptimer.h, include/rtems/posix/semaphore.h, include/rtems/posix/semaphoremp.h, inline/rtems/posix/cond.inl, inline/rtems/posix/intr.inl, inline/rtems/posix/key.inl, inline/rtems/posix/mqueue.inl, inline/rtems/posix/mutex.inl, inline/rtems/posix/pthread.inl, inline/rtems/posix/semaphore.inl, inline/rtems/posix/timer.inl, macros/rtems/posix/cond.inl, macros/rtems/posix/intr.inl, macros/rtems/posix/key.inl, macros/rtems/posix/mqueue.inl, macros/rtems/posix/mutex.inl, macros/rtems/posix/pthread.inl, macros/rtems/posix/semaphore.inl, macros/rtems/posix/timer.inl, src/alarm.c, src/kill.c, src/killinfo.c, src/mqueuetranslatereturncode.c, src/pause.c, src/pthreadattrdestroy.c, src/pthreadattrgetdetachstate.c, src/pthreadattrgetinheritsched.c, src/pthreadattrgetschedparam.c, src/pthreadattrgetschedpolicy.c, src/pthreadattrgetscope.c, src/pthreadattrgetstackaddr.c, src/pthreadattrgetstacksize.c, src/pthreadattrinit.c, src/pthreadattrsetdetachstate.c, src/pthreadattrsetinheritsched.c, src/pthreadattrsetschedparam.c, src/pthreadattrsetschedpolicy.c, src/pthreadattrsetscope.c, src/pthreadattrsetstackaddr.c, src/pthreadattrsetstacksize.c, src/pthreadcreate.c, src/pthreaddetach.c, src/pthreadequal.c, src/pthreadexit.c, src/pthreadgetcpuclockid.c, src/pthreadgetcputime.c, src/pthreadgetschedparam.c, src/pthreadjoin.c, src/pthreadkill.c, src/pthreadonce.c, src/pthreadself.c, src/pthreadsetcputime.c, src/pthreadsetschedparam.c, src/pthreadsigmask.c, src/sigaction.c, src/sigaddset.c, src/sigdelset.c, src/sigemptyset.c, src/sigfillset.c, src/sigismember.c, src/signal_2.c, src/sigpending.c, src/sigprocmask.c, src/sigqueue.c, src/sigsuspend.c, src/sigtimedwait.c, src/sigwait.c, src/sigwaitinfo.c, src/ualarm.c: URL for license changed.
* 2002-12-06 Vladimir Nesic <vnesic@dkts.co.yu>Joel Sherrill2002-12-061-9/+30
| | | | | | * inline/rtems/posix/cond.inl, macros/rtems/posix/cond.inl: Implemented PTHREAD_COND_INITIALIZER support. Vladimir implemented the inline version and Joel adapted it to the macro version.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-3/+6
* Added commit about missing support for condition initializer.Joel Sherrill1997-08-221-0/+1
* switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE"Joel Sherrill1996-07-031-4/+4
* posix support initially addedJoel Sherrill1995-09-261-0/+76
