line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Make the id the first parameter since usual callers get the object
identifier as the first parameter themself.
This functions supports only local objects. Thus, drop the location
parameter which was unused by all callers.
Remove superfluous includes from Classic Region implementation.
Yields higher performance on SMP systems.
Close #2625.
Update #2408.
Replace the extend function with an allocator since this fits better
to the current use case.
Remove compare function and is unique indicator from the control
structure. Rename RBTree_Compare_function to RBTree_Compare. Rename
rtems_rbtree_compare_function to rtems_rbtree_compare. Provide C++
compatible initializers. Add compare function and is unique indicator
to _RBTree_Find(), _RBTree_Insert(), rtems_rbtree_find() and
rtems_rbtree_insert(). Remove _RBTree_Is_unique() and
rtems_rbtree_is_unique(). Remove compare function and is unique
indicator from _RBTree_Initialize_empty() and
rtems_rbtree_initialize_empty().
Use the POSIX configuration value directly. Use right type early and
avoid casts. Use proper unlimited objects API. Check workspace
allocation. Make functions static.
Move implementation specific parts of key.h and key.inl into new header
file keyimpl.h. The key.h contains now only the application visible
API.
