path: root/cpukit/mghttpd (follow)
* cpukit/mghttpd: Support all descriptors in selectChris Johns2021-08-191-0/+31
| | | | | | | | - Support all possible descriptors in a select call. Borrowed from Christain and his mDNS change in LibBSD - If select (or poll) fails pause for a bit rather than locking up in a hard loop
* mghttpd/mongoose: Fix string truncation warningFrank Kühndel2020-10-101-2/+2
| | | | | | | | This fixes the compiler warning below. ../../../cpukit/mghttpd/mongoose.c:1919:45: warning: '.gz' directive output may be truncated writing 3 bytes into a region of size between 1 and 255 [-Wformat-truncation=]
* build: Merge mghttpd/Makefile.amSebastian Huber2018-10-101-15/+0
* build: Remove specialized CPPFLAGSSebastian Huber2018-10-091-2/+0
* mghttpd: Add configuration to source fileSebastian Huber2018-10-042-2/+4
| | | | Update #3375.
* cpukit/mttpd: Add a callback to generate a per file HTTP etagChris Johns2018-04-111-6/+13
| | | | Close #3323.
* Remove make preinstallChris Johns2018-01-253-435/+5
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | A speciality of the RTEMS build system was the make preinstall step. It copied header files from arbitrary locations into the build tree. The header files were included via the -Bsome/build/tree/path GCC command line option. This has at least seven problems: * The make preinstall step itself needs time and disk space. * Errors in header files show up in the build tree copy. This makes it hard for editors to open the right file to fix the error. * There is no clear relationship between source and build tree header files. This makes an audit of the build process difficult. * The visibility of all header files in the build tree makes it difficult to enforce API barriers. For example it is discouraged to use BSP-specifics in the cpukit. * An introduction of a new build system is difficult. * Include paths specified by the -B option are system headers. This may suppress warnings. * The parallel build had sporadic failures on some hosts. This patch removes the make preinstall step. All installed header files are moved to dedicated include directories in the source tree. Let @RTEMS_CPU@ be the target architecture, e.g. arm, powerpc, sparc, etc. Let @RTEMS_BSP_FAMILIY@ be a BSP family base directory, e.g. erc32, imx, qoriq, etc. The new cpukit include directories are: * cpukit/include * cpukit/score/cpu/@RTEMS_CPU@/include * cpukit/libnetworking The new BSP include directories are: * bsps/include * bsps/@RTEMS_CPU@/include * bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILIY@/include There are build tree include directories for generated files. The include directory order favours the most general header file, e.g. it is not possible to override general header files via the include path order. The "bootstrap -p" option was removed. The new "bootstrap -H" option should be used to regenerate the "headers.am" files. Update #3254.
* mghttpd: Include <mghttpd/mongoose.h>Sebastian Huber2017-12-131-1/+1
| | | | | | Prepare for header file move to common include directory. Update #3254.
* Move printer initialization to separate headerSebastian Huber2016-06-221-1/+1
| | | | | | The RTEMS print user need to know nothing about a particular printer implementation. In particular get rid of the <stdio.h> include which would be visible via <rtems.h>.
* mghttpd: Add RTEMS printer supportSebastian Huber2016-06-062-0/+16
* Enable WebSocket support in the Mongoose HTTP serverNick Withers2014-12-151-1/+1
* Regenerate all preinstall.am files.Joel Sherrill2014-08-281-6/+6
| | | | | Apparently, at some point automake output changed and these were not updated.
* Update to Mongoose 3.9 at the last point before the MIT -> GPL license changeNick Withers2013-12-043-1403/+2572
| | | | | | | | | | | | | | | | | | | | [That is, https://github.com/cesanta/mongoose/commit/04fc209644b414d915c446bb1815b55e9fe63acc. See https://groups.google.com/forum/#!topic/mongoose-users/aafbOnHonkI] The RTEMS patches described in the following emails and made to the previous Mongoose base have been applied: - http://www.rtems.org/pipermail/rtems-devel/2012-July/001345.html - http://www.rtems.org/pipermail/rtems-devel/2012-July/001343.html - http://www.rtems.org/pipermail/rtems-devel/2012-July/001346.html (except to mongoose.1, see below) ...as well as a patch very similar to that discussed at http://forums.bannister.org/ubbthreads.php?ubb=showflat&topic=7600&gonew=1 to provide poll() (which might be able to go away soon, with incoming RTEMS poll() support) mg_connect(), mg_url_encode() and mg_vprintf() were additionally marked "static" to silence warnings. mongoose.1 appears to have been removed from the upstream distribution. Note that the API's changed, for example: - A struct mg_callbacks must now be provided to mg_start(). Initialise members to NULL to disable various types of callbacks - Callback interfaces have changed significantly in general - The short form of options (e.g., "u" instead of "run_as_user") are no longer available (upstream) - The "max_request_size" options has been removed
* mghttpd: Requires POSIX to build server and testsJoel Sherrill2012-10-032-0/+4
| | | | | | Formerly, mghttpd was conditional only on networking being enabled. It uses on pthread and must also be conditional on POSIX threads support being enabled.
* mghttpd: Clarify commentChristian Mauderer2012-07-121-4/+4
* mghttpd: Add stack size and scheduling optionsChristian Mauderer2012-07-122-0/+66
* mghttpd: Use MD5 librarySebastian Huber2012-07-121-0/+5
* mghttpd: Use HAVE_CONFIG_HSebastian Huber2012-07-121-0/+4
* mghttpd: Update MongooseChristian Mauderer2012-07-124-4797/+4292
| | | | | | Update to Mongoose Mercurial revision 268:38a02c8a6744 available at: https://code.google.com/p/mongoose/
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-113-5/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-1/+0
* Whitespace removal.Ralf Corsepius2009-12-101-3/+3
* 2009-11-23 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-11-231-0/+6
| | | | | * mghttpd/mongoose.c: crypto_sw table is not used when SSL is disabled. RTEMS does not have flockfile/funlockfile.
* Various 16bit fixes.Ralf Corsepius2009-11-171-7/+7
* Add HAVE_CONFIG_H.Ralf Corsepius2009-11-171-0/+4
* Add HAVE_SYS_MMAN_H HAVE_DLFCN_H.Ralf Corsepius2009-11-171-0/+4
* Convert to unix encoding.Ralf Corsepius2009-11-172-4978/+4978
* New.Ralf Corsepius2009-11-173-0/+56
* 2009-11-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-11-173-0/+5159
* mghttpd/mongoose.c, mghttpd/mongoose.h, mghttpd/mongoose.1: Import from svn http://mongoose.googlecode.com/svn/trunk (r477).
