* | libtest: Change verbosity to normal | Sebastian Huber | 2023-12-19 | 1 | -1/+1 |
| | | | | | A verbose verbosity is not required for normal test suite runs. It may be used to debug test cases. | ||||
* | libtest: Fix test printer in rtems_test_run() | Sebastian Huber | 2023-12-14 | 1 | -2/+11 |
| | | | | | Route the test output through T_vprintf() only while the test suite runs. Otherwise, the begin/end of test message may not show up. | ||||
* | libtest: Set test printer in rtems_test_run() | Sebastian Huber | 2023-12-14 | 1 | -3/+11 |
| | | | | Route the test output through T_vprintf(). | ||||
* | Update company name | Sebastian Huber | 2023-05-20 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | libtest: Make test case allocator configurable | Sebastian Huber | 2020-11-19 | 1 | -0/+4 |
* | libtest: Add rtems_test_run() | Sebastian Huber | 2020-07-23 | 1 | -0/+87 |
Update #3199. |
