This unused variable causes a warning. It is never set or used.
Make sure there is no spurious empty line between the gcov info and the
*** END OF GCOV INFO BASE64 ***
line. This helps to recalculate the hash correctly at the consumer
side.
This helps to validate that the data was transferred correctly.
Move <rtems/score/gcov.h> to <rtems/test-gcov.h>. These functions do
not belong to an super core service.
brains GmbH.
Update #4670.
