Canonicalize the file headers.
Update #3707.
brains GmbH.
Flexible array members must not appear in the middle of a structure.
If RTEMS_DEBUG is not defined, then we have to explicitly set the node
off the chain.
Update #3199.
Do not set up a new test steps environment.
Update #3199.
Add support to record thread switch events. This can be used to check
that a blocking operation results in the expected sequence of thread
switches.
Update #3199.
