Update #3850
Update #3375.
* librpc/include/rpc/types.h: Include <rtems/stdint.h>.
* librpc/src/rpc/clnt_raw.c, librpc/src/rpc/rpcdname.c,
librpc/src/rpc/rtems_portmapper.c, librpc/src/rpc/svc.c,
librpc/src/rpc/svc_simple.c: Misc. cast-related fixes.
Convert to ANSI.
* librpc/include/rpc/rpc.h (struct _rtems_rpc_task_variables):
Use pointers to types instead of void* to avoid casts.
* librpc/src/rpc/clnt_perror.c, librpc/src/rpc/clnt_raw.c,
librpc/src/rpc/clnt_simple.c, librpc/src/rpc/rpcdname.c,
librpc/src/rpc/svc.c, librpc/src/rpc/svc_auth.c,
Eliminate lvalue casts gcc-3.4 warns about.
* include/rpc/rpc.hinclude/rpc/rpc.h: Rename struct
rtems_rpc_task_variables into struct _rtems_rpc_task_variables
(Avoid symbol conflict between struct and variable).
struct _rtems_rpc_task_variables *rtems_rpc_task_variables;
Reflect changes above.
* src/rpc/clnt_perror.c, src/rpc/clnt_raw.c, src/rpc/clnt_simple.c,
src/rpc/rpcdname.c, src/rpc/rtems_rpc.c, src/rpc/svc.c,
src/rpc/svc_auth.c, src/rpc/svc_raw.c, src/rpc/svc_simple.c:
* src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/pmap_rmt.c,
src/rpc/rtime.c, src/rpc/svc_tcp.c: Add include of <sys/select.h>
to eliminate warning.
* src/rpc/rpcdname.c: Add prototype of getdomainname() to eliminate
warning.
