* | cpukit: Remove libnetworking | Vijay Kumar Banerjee | 2021-04-07 | 1 | -97/+0 |
| | | | | Update #3850 | ||||
* | Remove CVS Id Strings (manual edits after script) | Joel Sherrill | 2012-05-11 | 1 | -2/+0 |
| | | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns. | ||||
* | Cosmetics from FreeBSD. | Ralf Corsepius | 2009-02-10 | 1 | -6/+32 |
* | Use -D_KERNEL instead of -DKERNEL for greater FreeBSD compliance. | Ralf Corsepius | 2004-04-20 | 1 | -1/+1 |
* | Base files | Joel Sherrill | 1998-08-19 | 1 | -0/+73 |
