Update #3850
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Prevent accidental use of legacy network header files.
Update #2833.
Do not use the MSIZE for the legacy network stack. Instead use
_SYS_MBUF_LEGACY_MSIZE.
Update #2833.
Import the <sys/socket.h> from current FreeBSD. This allows to build
some current software (e.g. libressl).
Close #2748.
Import the <sys/_sockaddr_storage.h> from current FreeBSD. Necessary
for <netinet/in.h> update.
Ensure that kernel and user space system call protoypes are identical.
closes 2245
This was needed to make it possible to only include <sys/socket.h>
for the methods in this file in compliance with the POSIX
specification. This was identified by the Open Group FACE
Conformance Test Suite.
Close 2245.
The so_uid is always 0 in RTEMS.
These two header files were installed from libnetworking even
when networking was disabled. This patch moves them to a
non-networking location and updates uio.h to match the FreeBSD 8.x
source being used for the USB stack and TCP/IP stack upgrade.
- cpukit/include/memory.h
Move from cpukit/libnetworking/memory.h. No changes
- cpukit/include/sys/uio.h
Move from cpukit/libnetworking/sys/uio.h. Replace with FreeBSD 8.x version.
- cpukit/include/sys/_iovec.h
New. FreeBSD 8.x file supporting <sys/uio.h>.
- cpukit/Makefile.am
Reflect movement of <memory.h> and <sys/uio.h>.
- cpukit/preinstall.am
Regenerate
- cpukit/libnetworking/nfs/bootp_subr.c
Eliminate use of uio_procp field no longer in FreeBSD structure. This
field was set and never read so eliminating the set has no impact.
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
* libnetworking/sys/signalvar.h: Cosmetics from FreeBSD.
Comment out psignal().
* libnetworking/sys/linker_set.h: Add local versions of __used
and __CONCAT macros.
* libnetworking/sys/signalvar.h: Comment out unused code.
* libnetworking/sys/socketvar.h (struct sockbuf):
Use void* instead of caddr_t.
* libnetworking/sys/socket.h (struct sockwakeup):
* libnetworking/sys/mbuf.h: Use uintptr_t instead of u_long
for 16bit target compliance.
* libnetworking/sys/sysctl.h: Change sysctl_oid->arg2 into int32_t
* libnetworking/sys/uio.h: Include <sys/types.h>.
Use ssize_t for uio_resid in struct uio (From FreeBSD).
* libnetworking/sys/kernel.h: Remove execsw_set,
si_elem_t (Unused, not in FreeBSD).
#include <sys/linker_set.h>.
Add #ifdef _KERNEL guards (From FreeBSD).
* libnetworking/sys/kernel.h: Remove hostnamelen, domainnamelen,
lbolt, tickdelta, timedelta (Unused, not in FreeBSD).
* libnetworking/lib/ftpfs.c, libnetworking/libc/inet_ntoa.c,
libnetworking/libc/rcmd.c, libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_glue.c,
libnetworking/rtems/rtems_malloc_mbuf.c,
libnetworking/rtems/rtems_showicmpstat.c, libnetworking/sys/malloc.h:
Fix some warnings.
PR 1262/filesystem
* libcsupport/Makefile.am, libnetworking/libc/herror.c,
libnetworking/libc/res_send.c, libnetworking/sys/uio.h,
telnetd/Makefile.am, telnetd/README, telnetd/preinstall.am,
telnetd/pty.c, telnetd/telnetd.c: Add support for readv() and
writev() including documentation and test case.
* libcsupport/src/readv.c, libcsupport/src/writev.c: New files.
* libnetworking/sys/buf.h: Remove unused/non-implemented bsd kernel
symbols.
Update copyright notice.
Remove unused/non-implemented declarations.
* libnetworking/sys/systm.h: Update copyright notice from FreeBSD.
Remove many non-supported/unused declarations.
