Update #3850
Import the <netdb.h> from current FreeBSD. This allows to build some
current software (e.g. libressl).
Add __h_errno().
Update gethostent_r() API. Linux and FreeBSD use a common API now.
Adapt the RTEMS one to provide the same one.
Match gethostbyname_r() with prototype.
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
* libnetworking/resolv.h: Partial sync with FreeBSD.
Add decls for res_send_setqhook, res_send_setrhook.
* libnetworking/resolv.h: Typo fixes. Remove __P().
