* | cpukit: Remove libnetworking | Vijay Kumar Banerjee | 2021-04-07 | 1 | -2151/+0 |
| | | | | Update #3850 | ||||
* | network: Use kernel/user space header files | Sebastian Huber | 2018-09-10 | 1 | -0/+2 |
| | | | | | | | | | | Add and use <machine/rtems-bsd-kernel-space.h> and <machine/rtems-bsd-user-space.h> similar to the libbsd to avoid command line defines and defines scattered throught the code base. Simplify cpukit/libnetworking/Makefile.am. Update #3375. | ||||
* | network: Header file compatiblity | Sebastian Huber | 2017-06-07 | 1 | -0/+1 |
| | | | | | | | | Move legacy network stack implementation specifics to <rtems/rtems_bsdnet_internal.h>. Include missing header files. Add interface flags compatibility. Update #2833. | ||||
* | network: Use inet_ntoa_r() | Sebastian Huber | 2017-06-07 | 1 | -4/+4 |
* | libnetworking: Import current <netinet/in.h> | Christian Mauderer | 2016-06-28 | 1 | -0/+1 |
| | | | | | | | | | | | | | | | | Import the <netinet/in.h> from current FreeBSD. This allows to build some current software (e.g. libressl). Add legacy support like * prototype for in_cksum(), * IPPORT_USERRESERVED, * deprecated IPCTL_RT* defines, * ip_fw_chk_t and ip_fw_ctl_t, * ip_nat_... (IP NAT hooks), and * IP_NAT option for get/setsockopt() to new <rtems/rtems_netinet_in.h>. | ||||
* | Remove CVS Id Strings (manual edits after script) | Joel Sherrill | 2012-05-11 | 1 | -1/+0 |
| | | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns. | ||||
* | Use <sys/queue.h> instead of <rtems/bsd/sys/queue.h. | Ralf Corsepius | 2011-03-02 | 1 | -1/+1 |
* | Add HAVE_CONFIG_H support to let files receive configure defines. | Ralf Corsepius | 2010-03-28 | 1 | -0/+4 |
* | Include <errno.h> (POSIX,C99) instead of <sys/errno.h> (BSD'ism). | Ralf Corsepius | 2008-12-22 | 1 | -1/+1 |
* | Stop using old-style function definitions. | Ralf Corsepius | 2008-09-01 | 1 | -26/+9 |
* | Remove BSD "Add clause" (From FreeBSD). | Ralf Corsepius | 2008-09-01 | 1 | -4/+0 |
* | Include <rtems/bsd/sys/queue.h> instead of <sys/queue.h>. | Ralf Corsepius | 2007-05-10 | 1 | -1/+1 |
* | Eliminate __P(). | Ralf Corsepius | 2007-03-28 | 1 | -6/+6 |
* | 2005-05-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-12 | 1 | -16/+16 |
| | | | | | * libnetworking/netinet/tcp_var.h: Partial update from FreeBSD. * libnetworking/netinet/tcp_input.c: Reflect changes to tcp_var.h. | ||||
* | PR 730 | Greg Menke | 2004-12-06 | 1 | -4/+4 |
| | | | | | * cpu_asm.S: Collected PR 601 changes for commit to cvshead for rtems-4.7 | ||||
* | 2002-10-04 Jay Monkman <jtm@smoothsmoothie.com> | Joel Sherrill | 2002-10-04 | 1 | -3/+18 |
| | | | | | | * netinet/in_cksum.c, netinet/ip_icmp.h, netinet/ip_input.c, netinet/tcp_input.c, netinet/tcp_subr.c, netinet/tcp_var.h, sys/queue.h: Address alignment requirements for the ARM. | ||||
* | 2000-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-01 | 1 | -1/+1 |
| | | | | * netinet/tcp_input.c: Spelling corrections. | ||||
* | Patch from D. V. Henkel-Wallace <gumby@zembu.com> to fix braces nesting problem. | Joel Sherrill | 1999-01-04 | 1 | -1/+2 |
* | All warnings removed. | Joel Sherrill | 1998-08-21 | 1 | -1/+1 |
* | Base files | Joel Sherrill | 1998-08-19 | 1 | -0/+2149 |
