* | cpukit: Remove libnetworking | Vijay Kumar Banerjee | 2021-04-07 | 1 | -386/+0 |
| | | | | Update #3850 | ||||
* | network: Use kernel/user space header files | Sebastian Huber | 2018-09-10 | 1 | -0/+2 |
| | | | | | | | | | | Add and use <machine/rtems-bsd-kernel-space.h> and <machine/rtems-bsd-user-space.h> similar to the libbsd to avoid command line defines and defines scattered throught the code base. Simplify cpukit/libnetworking/Makefile.am. Update #3375. | ||||
* | libnetworking: Import current <netinet/in.h> | Christian Mauderer | 2016-06-28 | 1 | -2/+1 |
| | | | | | | | | | | | | | | | | Import the <netinet/in.h> from current FreeBSD. This allows to build some current software (e.g. libressl). Add legacy support like * prototype for in_cksum(), * IPPORT_USERRESERVED, * deprecated IPCTL_RT* defines, * ip_fw_chk_t and ip_fw_ctl_t, * ip_nat_... (IP NAT hooks), and * IP_NAT option for get/setsockopt() to new <rtems/rtems_netinet_in.h>. | ||||
* | Use <sys/queue.h> instead of <rtems/bsd/sys/queue.h. | Ralf Corsepius | 2011-03-02 | 1 | -1/+1 |
* | Add HAVE_CONFIG_H support to let files receive configure defines. | Ralf Corsepius | 2010-03-28 | 1 | -0/+4 |
* | Include <rtems/bsd/sys/queue.h> instead of <sys/queue.h>. | Ralf Corsepius | 2007-05-10 | 1 | -1/+1 |
* | Eliminate __P(). | Ralf Corsepius | 2007-03-28 | 1 | -1/+1 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -1/+0 |
* | Base files | Joel Sherrill | 1998-08-19 | 1 | -0/+384 |
