Prevent accidental use of legacy network header files.
Update #2833.
Import the <netinet/in.h> from current FreeBSD. This allows to build
some current software (e.g. libressl).
Add legacy support like
* prototype for in_cksum(),
* IPPORT_USERRESERVED,
* deprecated IPCTL_RT* defines,
* ip_fw_chk_t and ip_fw_ctl_t,
* ip_nat_... (IP NAT hooks), and
* IP_NAT option for get/setsockopt()
to new <rtems/rtems_netinet_in.h>.
Re-base "struct in_addr" on in_addr_t (mandated by POSIX).
* libnetworking/netinet/in.h: Eliminate __P().
* libcsupport/include/sys/ioccom.h, libnetworking/kern/uipc_socket2.c,
libnetworking/net/ethernet.h, libnetworking/net/if.h,
libnetworking/net/if_ethersubr.c, libnetworking/net/if_ppp.c,
libnetworking/net/if_pppvar.h, libnetworking/net/ppp_tty.c,
libnetworking/net/pppcompress.c, libnetworking/net/slcompress.c,
libnetworking/netinet/in.h, libnetworking/netinet/ip_icmp.c,
libnetworking/netinet/tcp.h, libnetworking/netinet/tcp_seq.h,
libnetworking/sys/protosw.h, libnetworking/sys/socketvar.h: Remove
warnings. Most of the warnings were 16/32 bit integer sizing issues.
Some constants had L appended, some had casts add, some types were
changed to reflect a bit width requirement.
Remove BYTE_PACK.
* netinet/in.h: Per PR263, added include of <machine/endian.h>
to <netinet/in.h> so it includes prototypes of ntohl() family
of routines.
* netinet/in.h, netinet/ip.h, netinet/ip_var.h, netinet/tcp.h:
Modified to added packed attribute.o
