path: root/cpukit/libnetworking/libc/getproto.c (follow)
* cpukit: Remove libnetworkingVijay Kumar Banerjee2021-04-071-62/+0
| | | | Update #3850
* network: Use kernel/user space header filesSebastian Huber2018-09-101-0/+2
| | | | | | | | | | Add and use <machine/rtems-bsd-kernel-space.h> and <machine/rtems-bsd-user-space.h> similar to the libbsd to avoid command line defines and defines scattered throught the code base. Simplify cpukit/libnetworking/Makefile.am. Update #3375.
* Stop using old-style function-definitions.Ralf Corsepius2008-08-271-2/+2
* Eliminate SCCS, LINT. Add HAVE_CONFIG_H.Ralf Corsepius2007-03-301-3/+3
* 2003-01-27 Till Straumann <strauman@SLAC.Stanford.edu>Joel Sherrill2003-01-271-0/+5
| | | | | * libc/getproto.c, libc/getprotoname.c: modification to call getprotoent_static() if fopen() on /etc/protocols fails.
* Added CVS IdsJoel Sherrill1998-08-201-0/+2
* Base filesJoel Sherrill1998-08-191-0/+55
