path: root/cpukit/libmisc/rtmonuse/Makefile.am (follow)
* 2003-11-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-281-42/+0
| | | | | | | | | | | | | | | | | * capture/Makefile.am: Remove. * cpuuse/Makefile.am: Remove. * devnull/Makefile.am: Remove. * dummy/Makefile.am: Remove. * dumpbuf/Makefile.am: Remove. * fsmount/Makefile.am: Remove. * monitor/Makefile.am: Remove. * mw-fb/Makefile.am: Remove. * rtmonuse/Makefile.am: Remove. * serdbg/Makefile.am: Remove. * shell/Makefile.am: Remove. * stackchk/Makefile.am: Remove. * untar/Makefile.am: Remove. * Makefile.am: Merge-in the Makefile.ams above.
* 2003-11-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-201-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * capture/config.h: Remove. * capture/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * cpuuse/config.h: Remove. * cpuuse/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * devnull/config.h: Remove. * devnull/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * dummy/config.h: Remove. * dummy/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * dumpbuf/config.h: Remove. * dumpbuf/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * monitor/config.h: Remove. * monitor/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * mw-fb/config.h: Remove. * mw-fb/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * rtmonuse/config.h: Remove. * rtmonuse/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * serdbg/config.h: Remove. * serdbg/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * shell/config.h: Remove. * shell/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * stackchk/config.h: Remove. * stackchk/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * untar/config.h: Remove. * untar/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir).
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-081-3/+5
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * configure.ac: Remove (Merged into ../configure.ac). * Makefile.am: Reflect having merged configure.ac into ../configure.ac. * capture/config.h: New. * capture/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * cpuuse/config.h: New. * cpuuse/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * devnull/config.h: New. * devnull/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * dummy/config.h: New. * dummy/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * dumpbuf/config.h: New. * dumpbuf/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * monitor/config.h: New. * monitor/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * mw-fb/config.h: New. * mw-fb/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * rtmonuse/config.h: New. * rtmonuse/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * serdbg/config.h: New. * serdbg/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * shell/config.h: New. * shell/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * stackchk/config.h: New. * stackchk/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * untar/config.h: New. * untar/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * wrapup/Makefile.am: Reflect having merged configure.ac into ../configure.ac.
* 2002-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-241-1/+1
| | | | | | | | | | | | | | | | | | | | | * configure.ac: Add check for weak function attribute. Remove AM_CONDITIONAL([RTEMS_LIBSHELL]. Add AM_CONDITIONAL(LIBSHELL), AM_CONDITIONAL(LIBSERDBG). * capture/Makefile.am: Use *.a instead of *-tmp.a. * cpuuse/Makefile.am: Use *.a instead of *-tmp.a. * devnull/Makefile.am: Use *.a instead of *-tmp.a. * dummy/Makefile.am: Use *.a instead of *-tmp.a. * dumpbuf/Makefile.am: Use *.a instead of *-tmp.a. * monitor/Makefile.am: Use *.a instead of *-tmp.a. * mw-fb/Makefile.am: Use *.a instead of *-tmp.a. * rtmonuse/Makefile.am: Use *.a instead of *-tmp.a. * serdbg/Makefile.am: Use *.a instead of *-tmp.a. Build iff LIBSERDBG is true. * shell/Makefile.am: Use *.a instead of *-tmp.a. Build iff LIBSHELL is true. * stackchk/Makefile.am: Use *.a instead of *-tmp.a. * untar/Makefile.am: Use *.a instead of *-tmp.a. * wrapup/Makefile.am: Reflect changes above.
* 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-121-3/+1
| | | | | | | | | | | | | | | | | * configure.ac: Require autoconf-2.57+automake-1.7.2. * capture/Makefile.am: Eliminate C_O_FILES. * cpuuse/Makefile.am: Ditto. * devnull/Makefile.am: Ditto. * dummy/Makefile.am: Ditto. * dumpbuf/Makefile.am: Ditto. * monitor/Makefile.am: Ditto. * rtmonuse/Makefile.am: Ditto. * serdbg/Makefile.am: Ditto. * shell/Makefile.am: Ditto. * stackchk/Makefile.am: Ditto. * untar/Makefile.am: Ditto. * mw-fb/Makefile.am: Eliminate C_O_FILES. Eliminate SRCS.
* 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-121-4/+4
| | | | | | | | | | | | | | | | | | | | | | | Moving libmisc from rtems/c/src to rtems/cpukit. * Makefile.am: Reflect new path. * configure.ac: Reflect new path. Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP. Remove RTEMS_PROJECT_ROOT. * capture/Makefile.am: Reflect new path. Remove OBJS from all-local. * cpuuse/Makefile.am: Ditto. * devnull/Makefile.am: Ditto. * dummy/Makefile.am: Ditto. * dumpbuf/Makefile.am: Ditto. * monitor/Makefile.am: Ditto. * mw-fb/Makefile.am: Ditto. * rtmonuse/Makefile.am: Ditto. * serdbg/Makefile.am: Ditto. * shell/Makefile.am: Ditto. * stackchk/Makefile.am: Ditto. * untar/Makefile.am: Ditto. * wrapup/Makefile.am: Reflect new path.
* 2002-12-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-101-1/+0
| | | | | | | | | | | | | | | | * capture/Makefile.am: Don't include @RTEMS_BSP@.cfg. * cpuuse/Makefile.am: Don't include @RTEMS_BSP@.cfg. * devnull/Makefile.am: Don't include @RTEMS_BSP@.cfg. * dummy/Makefile.am: Don't include @RTEMS_BSP@.cfg. * dumpbuf/Makefile.am: Don't include @RTEMS_BSP@.cfg. * monitor/Makefile.am: Don't include @RTEMS_BSP@.cfg. * mw-fb/Makefile.am: Don't include @RTEMS_BSP@.cfg. * rtmonuse/Makefile.am: Don't include @RTEMS_BSP@.cfg. * serdbg/Makefile.am: Don't include @RTEMS_BSP@.cfg. * shell/Makefile.am: Don't include @RTEMS_BSP@.cfg. * stackchk/Makefile.am: Don't include @RTEMS_BSP@.cfg. * untar/Makefile.am: Don't include @RTEMS_BSP@.cfg. * wrapup/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-1/+1
| | | | | | | | | | | | | | | * capture/Makefile.am: Use .$(OBJEXT) instead of .o. * cpuuse/Makefile.am: Use .$(OBJEXT) instead of .o. * devnull/Makefile.am: Use .$(OBJEXT) instead of .o. * dummy/Makefile.am: Use .$(OBJEXT) instead of .o. * dumpbuf/Makefile.am: Use .$(OBJEXT) instead of .o. * monitor/Makefile.am: Use .$(OBJEXT) instead of .o. * mw-fb/Makefile.am: Use .$(OBJEXT) instead of .o. * rtmonuse/Makefile.am: Use .$(OBJEXT) instead of .o. * serdbg/Makefile.am: Use .$(OBJEXT) instead of .o. * shell/Makefile.am: Use .$(OBJEXT) instead of .o. * stackchk/Makefile.am: Use .$(OBJEXT) instead of .o. * untar/Makefile.am: Use .$(OBJEXT) instead of .o.
| | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. * cpuuse/Makefile.am: Remove AUTOMAKE_OPTIONS. * devnull/Makefile.am: Remove AUTOMAKE_OPTIONS. * dummy/Makefile.am: Remove AUTOMAKE_OPTIONS. * dumpbuf/Makefile.am: Remove AUTOMAKE_OPTIONS. * monitor/Makefile.am: Remove AUTOMAKE_OPTIONS. * mw-fb/Makefile.am: Remove AUTOMAKE_OPTIONS. * rootfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtmonuse/Makefile.am: Remove AUTOMAKE_OPTIONS. * shell/Makefile.am: Remove AUTOMAKE_OPTIONS. * stackchk/Makefile.am: Remove AUTOMAKE_OPTIONS. * untar/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-281-1/+1
| | | | | | | | | | | | | * untar/Makefile.am: Use 'PREINSTALL_FILES ='. * monitor/Makefile.am: Use 'PREINSTALL_FILES ='. * shell/Makefile.am: Use 'PREINSTALL_FILES ='. * devnull/Makefile.am: Use 'PREINSTALL_FILES ='. * dumpbuf/Makefile.am: Use 'PREINSTALL_FILES ='. * mw-fb/Makefile.am: Use 'PREINSTALL_FILES ='. * stackchk/Makefile.am: Use 'PREINSTALL_FILES ='. * rtmonuse/Makefile.am: Use 'PREINSTALL_FILES ='. * cpuuse/Makefile.am: Use 'PREINSTALL_FILES ='. * rootfs/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-3/+5
| | | | | | | * untar/Makefile.am, monitor/Makefile.am, dummy/Makefile.am, devnull/Makefile.am, dumpbuf/Makefile.am, mw-fb/Makefile.am, stackchk/Makefile.am, rtmonuse/Makefile.am, cpuuse/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | | * cpuuse/Makefile.am, dummy/Makefile.am, dumpbuf/Makefile.am, monitor/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, untar/Makefile.am, wrapup/Makefile.am, mw-fb/Makefile.am: Include compile.am.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-2/+2
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-081-15/+14
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-231-1/+1
| | | | to convert the libmisc directory from Makefile.in to Makefile.am.
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-221-0/+42
.. a major configuration cleanup ... major enhancement of automake support. ... and it contains a *major* breakthough: Automake support for libchip and libmisc *LEAF* directories. To implement this I have used several nasty tricks * The basical trick is to wrap an old Makefile.in's contents into a Makefile.am and still continue to use (i.e include) the old *.cfg files. * Replaced each INSTALL_IF_CHANGE and INSTALL_VARIANT with make dependencies * Add a gnu-make ifdef AUTOMAKE to main.cfg to avoid conflicts between automake and RTEMS make rules * Replaced each install:: and preinstall:: rule with make dependencies * Replaced SUB_DIRS with SUBDIRS in all Makefile.ins (Automake convention) * Removed each manually added autoconf substitution which automake performs automatically. This is not yet full automake support, because using the temporary installation directory, preinstallation in general and building variants are in contradiction to automake's basic working principles ... ... the new Makefile.ams work still somewhat clumsy ... nevertheless they work (quite well). WARNING: At first glance this patch is small, but * it affects the whole configuration system. * it opens the road to introducing automake to all Makefile.ins currently not being under automake control. JOEL> Does this remove or add any files? Both, all Makefile.ins below libchip and libmisc get replaced with Makefile.ams.
