Updates #3053.
Update #3530.
Update #3533.
Update #2843.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Prepare for header file move to common include directory.
Update #3254.
Update #2133.
take more than 16-bit constants
overflow 16-bit int
Rename rtems_stdio_redirect_t to rtems_stdio_redirect since the
namespace *_t is reserved by POSIX, see also The Open Group Base
Specifications Issue 6 IEEE Std 1003.1, 2004 Edition, 2.2.2 The Name
Space.
This module makes it easy to redirect and capture stdout, stderr or any
other fd in your application.
The captured data can be sent off board, for example using syslog,
or buffered and displayed in a web page.
