path: root/cpukit/libmisc/mouse/README (follow)
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-4/+0
* 2011-03-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-03-141-0/+214
PR 1762/cpukit * Makefile.am, preinstall.am, libmisc/Makefile.am, wrapup/Makefile.am: Add generic serial mouse driver and mouse parser. The parser code was in the pc386 BSP but was generic so cleaned up and placed here. Serial mouse driver itself is new. * libmisc/mouse/README, libmisc/mouse/mouse_parser.c, libmisc/mouse/mouse_parser.h, libmisc/mouse/serial_mouse.c, libmisc/mouse/serial_mouse.h: New files.
