brains GmbH.
Updates #3053.
Updates #4625.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
The output of the modules.html is much improved. Most
filesystem and POSIX API related groups are properly nested.
Some formatting issues were addressed as were multiple
inconsistencies.
Conflicts occured durning this patch and modifications in
the repo were favored over the patch.
* include/rtems/bspIo.h, include/rtems/concat.h,
include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h,
include/rtems/pci.h, include/rtems/userenv.h,
libblock/include/rtems/flashdisk.h,
libblock/include/rtems/nvdisk-sram.h,
libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h,
libcsupport/include/console.h, libcsupport/include/iosupp.h,
libcsupport/include/spurious.h,
libcsupport/include/motorola/mc68230.h,
libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h,
libcsupport/include/rtems/framebuffer.h,
libcsupport/include/rtems/gxx_wrappers.h,
libcsupport/include/rtems/libcsupport.h,
libcsupport/include/rtems/libio_.h,
libcsupport/include/rtems/malloc.h,
libcsupport/include/rtems/termiostypes.h,
libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h,
libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h,
libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h,
libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h,
libmisc/capture/capture-cli.h, libmisc/capture/capture.h,
libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h,
libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h,
libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h,
libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h,
libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h,
posix/include/mqueue.h, posix/include/semaphore.h,
posix/include/rtems/posix/aio_misc.h,
posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h,
posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/posixapi.h,
posix/include/rtems/posix/ptimer.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/sigset.h,
posix/include/rtems/posix/spinlock.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/inline/rtems/posix/timer.inl, rtems/mainpage.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/timer.h,
rtems/inline/rtems/rtems/barrier.inl,
rtems/inline/rtems/rtems/timer.inl,
rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h,
sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/priority.inl: Add @file Doxygen directives
and descriptions to files which originated with RTEMS. This improves
the file list page generated by Doxygen.
* libmisc/devnull/devzero.c, libmisc/devnull/devzero.h: New files.
* libmisc/Makefile.am, Makefile.am, preinstall.am: Reflect changes
above.
* libmisc/devnull/devnull.h, libmisc/stackchk/stackchk.h:
Fix header guard. Add missing includes.
* libmisc/capture/capture-cli.c, libmisc/capture/capture.c,
libmisc/capture/capture.h, libmisc/cpuuse/cpuuse.c,
libmisc/devnull/devnull.c, libmisc/fsmount/fsmount.h,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-dname.c,
libmisc/monitor/mon-driver.c, libmisc/monitor/mon-extension.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-mpci.c, libmisc/monitor/mon-object.c,
libmisc/monitor/mon-prmisc.c, libmisc/monitor/mon-queue.c,
libmisc/monitor/mon-server.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/monitor.h, libmisc/monitor/symbols.h,
libmisc/mw-fb/mw_uid.c, libmisc/rtmonuse/rtmonuse.c,
libmisc/serdbg/serdbg.h, libmisc/serdbg/serdbgio.c,
libmisc/serdbg/termios_printk.c, libmisc/serdbg/termios_printk.h,
libmisc/shell/shell.c, libmisc/shell/shell.h, libmisc/stackchk/check.c,
libmisc/stackchk/internal.h: Convert to using c99 fixed size types.
* capture/Makefile.am: Remove.
* cpuuse/Makefile.am: Remove.
* devnull/Makefile.am: Remove.
* dummy/Makefile.am: Remove.
* dumpbuf/Makefile.am: Remove.
* fsmount/Makefile.am: Remove.
* monitor/Makefile.am: Remove.
* mw-fb/Makefile.am: Remove.
* rtmonuse/Makefile.am: Remove.
* serdbg/Makefile.am: Remove.
* shell/Makefile.am: Remove.
* stackchk/Makefile.am: Remove.
* untar/Makefile.am: Remove.
* Makefile.am: Merge-in the Makefile.ams above.
* capture/config.h: Remove.
* capture/Makefile.am: Remove config.h.
AM_CPPFLAGS += -I$(top_builddir).
* cpuuse/config.h: Remove.
* cpuuse/Makefile.am: Remove config.h.
* devnull/config.h: Remove.
* devnull/Makefile.am: Remove config.h.
* dummy/config.h: Remove.
* dummy/Makefile.am: Remove config.h.
* dumpbuf/config.h: Remove.
* dumpbuf/Makefile.am: Remove config.h.
* monitor/config.h: Remove.
* monitor/Makefile.am: Remove config.h.
* mw-fb/config.h: Remove.
* mw-fb/Makefile.am: Remove config.h.
* rtmonuse/config.h: Remove.
* rtmonuse/Makefile.am: Remove config.h.
* serdbg/config.h: Remove.
* serdbg/Makefile.am: Remove config.h.
* shell/config.h: Remove.
* shell/Makefile.am: Remove config.h.
* stackchk/config.h: Remove.
* stackchk/Makefile.am: Remove config.h.
* untar/config.h: Remove.
* untar/Makefile.am: Remove config.h.
* cpuuse/cpuuse.c, cpuuse/cpuuse.h, devnull/devnull.c,
devnull/devnull.h, dummy/dummy.c, dumpbuf/dumpbuf.c,
dumpbuf/dumpbuf.h, fsmount/fsmount.c, fsmount/fsmount.h,
serdbg/serdbgio.c, serdbg/termios_printk.c, stackchk/check.c,
stackchk/internal.h, stackchk/stackchk.h, untar/untar.c,
untar/untar.h: URL for license changed.
* configure.ac: Remove (Merged into ../configure.ac).
* Makefile.am:
* capture/config.h: New.
* capture/Makefile.am: Add config.h.
* cpuuse/config.h: New.
* cpuuse/Makefile.am: Add config.h.
* devnull/config.h: New.
* devnull/Makefile.am: Add config.h.
* dummy/config.h: New.
* dummy/Makefile.am: Add config.h.
* dumpbuf/config.h: New.
* dumpbuf/Makefile.am: Add config.h.
* monitor/config.h: New.
* monitor/Makefile.am: Add config.h.
* mw-fb/config.h: New.
* mw-fb/Makefile.am: Add config.h.
* rtmonuse/config.h: New.
* rtmonuse/Makefile.am: Add config.h.
* serdbg/config.h: New.
* serdbg/Makefile.am: Add config.h.
* shell/config.h: New.
* shell/Makefile.am: Add config.h.
* stackchk/config.h: New.
* stackchk/Makefile.am: Add config.h.
* untar/config.h: New.
* untar/Makefile.am: Add config.h.
* wrapup/Makefile.am:
* capture/capture-cli.c: Add config-header support.
* capture/capture.c: Add config-header support.
* cpuuse/cpuuse.c: Add config-header support.
* devnull/devnull.c: Add config-header support.
* dummy/dummy.c: Add config-header support.
* dumpbuf/dumpbuf.c: Add config-header support.
* monitor/mon-command.c: Add config-header support.
* monitor/mon-config.c: Add config-header support.
* monitor/mon-dname.c: Add config-header support.
* monitor/mon-driver.c: Add config-header support.
* monitor/mon-extension.c: Add config-header support.
* monitor/mon-itask.c: Add config-header support.
* monitor/mon-manager.c: Add config-header support.
* monitor/mon-monitor.c: Add config-header support.
* monitor/mon-mpci.c: Add config-header support.
* monitor/mon-object.c: Add config-header support.
* monitor/mon-prmisc.c: Add config-header support.
* monitor/mon-queue.c: Add config-header support.
* monitor/mon-server.c: Add config-header support.
* monitor/mon-symbols.c: Add config-header support.
* monitor/mon-task.c: Add config-header support.
* mw-fb/mw_fb.c: Add config-header support.
* mw-fb/mw_uid.c: Add config-header support.
* rtmonuse/rtmonuse.c: Add config-header support.
* serdbg/serdbg.c: Add config-header support.
* serdbg/serdbgio.c: Add config-header support.
* serdbg/termios_printk.c: Add config-header support.
* shell/cmds.c: Add config-header support.
* stackchk/check.c: Add config-header support.
* untar/untar.c: Add config-header support.
* configure.ac: Add check for weak function attribute.
Remove AM_CONDITIONAL([RTEMS_LIBSHELL].
Add AM_CONDITIONAL(LIBSHELL), AM_CONDITIONAL(LIBSERDBG).
* capture/Makefile.am: Use *.a instead of *-tmp.a.
* cpuuse/Makefile.am: Use *.a instead of *-tmp.a.
* devnull/Makefile.am: Use *.a instead of *-tmp.a.
* dummy/Makefile.am: Use *.a instead of *-tmp.a.
* dumpbuf/Makefile.am: Use *.a instead of *-tmp.a.
* monitor/Makefile.am: Use *.a instead of *-tmp.a.
* mw-fb/Makefile.am: Use *.a instead of *-tmp.a.
* rtmonuse/Makefile.am: Use *.a instead of *-tmp.a.
* serdbg/Makefile.am: Use *.a instead of *-tmp.a.
Build iff LIBSERDBG is true.
* shell/Makefile.am: Use *.a instead of *-tmp.a.
Build iff LIBSHELL is true.
* stackchk/Makefile.am: Use *.a instead of *-tmp.a.
* untar/Makefile.am: Use *.a instead of *-tmp.a.
* configure.ac: Require autoconf-2.57+automake-1.7.2.
* capture/Makefile.am: Eliminate C_O_FILES.
* cpuuse/Makefile.am: Ditto.
* devnull/Makefile.am: Ditto.
* dummy/Makefile.am: Ditto.
* dumpbuf/Makefile.am: Ditto.
* monitor/Makefile.am: Ditto.
* rtmonuse/Makefile.am: Ditto.
* serdbg/Makefile.am: Ditto.
* shell/Makefile.am: Ditto.
* stackchk/Makefile.am: Ditto.
* untar/Makefile.am: Ditto.
* mw-fb/Makefile.am: Eliminate C_O_FILES.
Eliminate SRCS.
Moving libmisc from rtems/c/src to rtems/cpukit.
* Makefile.am: Reflect new path.
* configure.ac: Reflect new path.
Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP.
Remove RTEMS_PROJECT_ROOT.
* capture/Makefile.am: Reflect new path.
Remove OBJS from all-local.
* mw-fb/Makefile.am: Ditto.
* wrapup/Makefile.am: Reflect new path.
* capture/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* cpuuse/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* devnull/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* dummy/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* dumpbuf/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* monitor/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mw-fb/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* rtmonuse/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* serdbg/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shell/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* stackchk/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* untar/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* capture/Makefile.am: Use .$(OBJEXT) instead of .o.
* cpuuse/Makefile.am: Use .$(OBJEXT) instead of .o.
* devnull/Makefile.am: Use .$(OBJEXT) instead of .o.
* dummy/Makefile.am: Use .$(OBJEXT) instead of .o.
* dumpbuf/Makefile.am: Use .$(OBJEXT) instead of .o.
* monitor/Makefile.am: Use .$(OBJEXT) instead of .o.
* mw-fb/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtmonuse/Makefile.am: Use .$(OBJEXT) instead of .o.
* serdbg/Makefile.am: Use .$(OBJEXT) instead of .o.
* shell/Makefile.am: Use .$(OBJEXT) instead of .o.
* stackchk/Makefile.am: Use .$(OBJEXT) instead of .o.
* untar/Makefile.am: Use .$(OBJEXT) instead of .o.
* devnull/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dummy/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dumpbuf/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mw-fb/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rootfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shell/Makefile.am: Remove AUTOMAKE_OPTIONS.
* untar/Makefile.am: Remove AUTOMAKE_OPTIONS.
* untar/Makefile.am: Use 'PREINSTALL_FILES ='.
* monitor/Makefile.am: Use 'PREINSTALL_FILES ='.
* shell/Makefile.am: Use 'PREINSTALL_FILES ='.
* devnull/Makefile.am: Use 'PREINSTALL_FILES ='.
* dumpbuf/Makefile.am: Use 'PREINSTALL_FILES ='.
* mw-fb/Makefile.am: Use 'PREINSTALL_FILES ='.
* stackchk/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtmonuse/Makefile.am: Use 'PREINSTALL_FILES ='.
* cpuuse/Makefile.am: Use 'PREINSTALL_FILES ='.
* rootfs/Makefile.am: Use 'PREINSTALL_FILES ='.
* devnull/devnull.c: Eliminate warning.
* devnull/devnull.c (null_initialize): Added check to
ensure that the driver is only initialized once. Otherwise,
it will abort when the device /dev/null is present.
(null_write): Do not dereference a NULL pointer.
* untar/Makefile.am, monitor/Makefile.am, dummy/Makefile.am,
devnull/Makefile.am, dumpbuf/Makefile.am, mw-fb/Makefile.am,
stackchk/Makefile.am, rtmonuse/Makefile.am, cpuuse/Makefile.am:
* devnull: New addition. Moved from libcpu/sh.
* devnull/devnull.c, devnull/devnull.h, devnull/.cvsignore,
devnull/Makefile.am: New files.
* Makefile.am, configure.in, wrapup/Makefile.am: Modified to reflect
addition of above.
