line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This patches some issues with the capture engine:
1. Check is the engine is open in ctrace commands.
2. Check all record open and appends for overflow.
3. Fix the record open to take the size of user data and
not the record header.
4. Use packed structs for data being written to the per
cpu buffers.
5. Remove direct struct access to the capture buffers to
avoid misaligned accesses.
6. Add support to extract records, no struct access to the
capture buffers.
7. Update ctrace to extract records from the capture buffers.
8. Add support to ctrace to always print the task name if it
has one.
9. Add support to manage names or the lack of a name.
10. Range of minor fixes.
11. Fix a long standing bug in ctset's handling of args.
Closes #2780.
Get the current processor index only once and with interrupts disabled.
Close #2707.
To support smp data was broken into global and percpu capture data.
Capture control must be disabled prior to printing or setting of
watch points.
Methods to print the data were moved from capture-cli into
a support area and are no longer static so that they can
be shared by test routines, or application code that wants
to use the capture engine without the shell interface.
This patch removes functionality for stack checking from
the capture engine and requiresi the use of existing rtems
functions for this information. It modifies ctload to use
functionality similar to rtems cpuusage. It removes the
capture task and stores a new capture task record the first
time the task is seen. The per task data that was still
needed is scaled down and stored in the tcb.
