* | jffs2: Fix if/else empty body warnings | Randy Dunlap | 2023-01-12 | 1 | -11/+12 |
| | | | | | | | | | | | | | | | | | | | | When debug (print) macros are not enabled, change them to use the no_printk() macro instead of <nothing>. This fixes gcc warnings when -Wextra is used: ../cpukit/libfs/src/jffs2/src/nodelist.c:255:37: warning: suggest braces around empty body in an ‘else’ statement [-Wempty-body] ../cpukit/libfs/src/jffs2/src/nodelist.c:278:38: warning: suggest braces around empty body in an ‘else’ statement [-Wempty-body] ../cpukit/libfs/src/jffs2/src/nodelist.c:558:52: warning: suggest braces around empty body in an ‘else’ statement [-Wempty-body] ../cpukit/libfs/src/jffs2/src/xattr.c:1247:58: warning: suggest braces around empty body in an ‘if’ statement [-Wempty-body] ../cpukit/libfs/src/jffs2/src/xattr.c:1281:65: warning: suggest braces around empty body in an ‘if’ statement [-Wempty-body] Builds without warnings on all 3 levels of CONFIG_JFFS2_FS_DEBUG. Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Richard Weinberger <richard@nod.at> Cc: linux-mtd@lists.infradead.org Signed-off-by: Richard Weinberger <richard@nod.at> | ||||
* | JFFS2: Add RTEMS support | Sebastian Huber | 2013-09-19 | 1 | -0/+18 |
* | JFFS2: Import from Linux | Sebastian Huber | 2013-09-19 | 1 | -0/+275 |
Import of Journalling Flash File System, Version 2 from Linux 3.11. This part of the Linux kernel is under a separate license which is similar to the RTEMS license. The file "cpukit/libfs/src/jffs2/include/linux/jffs2.h" is a copy of "linux-3.11/include/uapi/linux/jffs2.h". The file "LICENSE.JFFS2" is a copy of "linux-3.11/fs/jffs2/LICENCE". The files "linux-3.11/fs/jffs2/LICENCE", "linux-3.11/fs/jffs2/acl.h", "linux-3.11/fs/jffs2/build.c", "linux-3.11/fs/jffs2/compr.c", "linux-3.11/fs/jffs2/compr.h", "linux-3.11/fs/jffs2/compr_rtime.c", "linux-3.11/fs/jffs2/compr_rubin.c", "linux-3.11/fs/jffs2/compr_zlib.c", "linux-3.11/fs/jffs2/debug.c", "linux-3.11/fs/jffs2/debug.h", "linux-3.11/fs/jffs2/erase.c", "linux-3.11/fs/jffs2/gc.c", "linux-3.11/fs/jffs2/jffs2_fs_i.h", "linux-3.11/fs/jffs2/jffs2_fs_sb.h", "linux-3.11/fs/jffs2/nodelist.c", "linux-3.11/fs/jffs2/nodelist.h", "linux-3.11/fs/jffs2/nodemgmt.c", "linux-3.11/fs/jffs2/read.c", "linux-3.11/fs/jffs2/readinode.c", "linux-3.11/fs/jffs2/scan.c", "linux-3.11/fs/jffs2/summary.h", "linux-3.11/fs/jffs2/write.c", and "linux-3.11/fs/jffs2/xattr.h" are copied to "cpukit/libfs/src/jffs2/src". |
