brains GmbH.
Updates #3053.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3894.
Update #3894.
Remove IMFS_NODE_FLAG_NAME_ALLOCATED and instead replace the node
control in rename operations. This avoids a special case in the general
node destruction which pulled in free().
Update #3894.
Prepare for header file move to common include directory.
Update #3254.
This helps to use IMFS_make_generic_node() without pulling in the
complete IMFS implementation.
