brains GmbH.
Update #3706.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #2843.
If there is already a file with a long file name it isn't possible to
create a second file which has a name that ends on the first files name
(for example ets.beam and sets.beam). This patch fixes that.
Update #3258.
Take care that a file in the root directory with the same name as the
volume name can be found.
Update #3257.
Update #2964.
Do not use our long file name entry count to optimize the file name
search. The Unicode comparison must be taken into account.
Update #2939.
The name "fat_entries" for long file name directory entries is quite
misleading.
Update #2934.
Make sure that long file names work accross cluster boundaries.
Update #2929.
Update #2929.
Update #2929.
Close #2755.
For a filename match the entry must match without anything remaining.
Close #2908.
closes #2756,
CodeSonar flagged the increment of this pointer as unneeded. The pointer
is not used past this point.
Implement ctime and mtime updates according to POSIX. The ctime is
mapped to the FAT create time and date. The mtime is mapped to the FAT
last modified time and date. For the atime use the mtime for
simplicity.
Also eliminates possibly dead code in case the name_type can never
actually be MSDOS_NAME_INVALID.
1063860 Logically dead code.
Add optional conversion methods for multibyte strings. With these
conversions which make use of iconv and utf8proc it becomes possible to
use strings from any language (Czech, Chinese, Arabian, Hebrew, Corean,
...) for file names and directory names.
NOTE: Iconv support must be activated during the build of the tool chain
for these conversion methods (options --enable-newlib-iconv
--enable-newlib-iconv-encodings=[ENCODINGS_YOU_WANT]). Alternatively
you can provide your own conversion methods.
User interface and backwards compatibility for UTF-8 support in the FAT
file system. Purpose of UTF-8 support is to permit file names and
directory names with characters from all kinds of languages (Czech,
Chinese, Arabian, Hebrew, Korean, ...). This commit does not yet
support multibyte characters. It only contains the user interface and
the backwards compatibility.
Separate cluster write from sector write for quick file write.
New test fstests/fsdosfswrite01.
The FAT32 FS info sector contains hints for the free cluster count and
the next free cluster. The previous code read these values during mount
and replaced them with invalid values. The shutdown operation updated
them with the current values. These values are only hints. Every FAT
implementation must cope with arbitrary values. They are intended to
speed up certain operations.
Now we update the free cluster count and next free culster in the FAT32
FS info sector only during unmount or sync operations and only if the
values have changed. This avoids writes to the FS info sector and
conforms to the behaviour of Linux and Windows.
The application can force an update of these values now with the fsync()
and fdatasync() operations. Applications that only read will perform
not write operations to the FAT32 FS info sector.
The new fat_sync() function performs all non-file specific
synchronizations.
The fat_file_datasync() read every cluster of the file into the cache
and then synchronized it step-by-step. For unmodified buffers this is a
non-operation. For modified buffers this will wake-up the swapout task
which performs then a single buffer write operation. This is usually
quite inefficient. Firstly we do single buffer writes, secondly we
may perform a lot of unnecessary read operations (for huge files this is
really bad), and thirdly this leads likely to cache evictions.
The synchronization procedure is replaced by a simple
rtems_bdbuf_sync_dev(). This has the side-effect that also buffers not
related to the file are synchronized, but since the modified list is
normally short this should be acceptable.
Space that grows due to truncate or write offsets beyond the current
file size must be zero filled.
o A new data structure rtems_filesystem_global_location_t was
introduced to be used for
o the mount point location in the mount table entry,
o the file system root location in the mount table entry,
o the root directory location in the user environment, and
o the current directory location in the user environment.
During the path evaluation global start locations are obtained to
ensure that the current file system instance will be not unmounted in
the meantime.
o The user environment uses now reference counting and is protected
from concurrent access.
o The path evaluation process was completely rewritten and simplified.
The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation
method. Recursive calls in the path evaluation have been replaced
with iteration to avoid stack overflows. Only the evaluation of
symbolic links is recursive. No dynamic memory allocations and
intermediate buffers are used in the high level path evaluation. No
global locks are held during the file system instance specific path
evaluation process.
o Recursive symbolic link evaluation is now limited by
RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value
via sysconf().
o The device file system (devFS) uses now no global variables and
allocation from the workspace. Node names are allocated from the
heap.
o The upper layer lseek() performs now some parameter checks.
o The upper layer ftruncate() performs now some parameter checks.
o unmask() is now restricted to the RWX flags and protected from
concurrent access.
o The fchmod_h and rmnod_h file system node handlers are now a file
system operation.
o The unlink_h operation has been removed. All nodes are now destroyed
with the rmnod_h operation.
o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system
operations.
o The path evaluation and file system operations are now protected by
per file system instance lock and unlock operations.
o Fix and test file descriptor duplicate in fcntl().
o New test fstests/fsnofs01.
* libfs/src/dosfs/msdos_misc.c: Don't include <strings.h>.
* libfs/src/dosfs/msdos_misc.c: Create short file names acceptable for
Windows.
* libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_misc.c,
libfs/src/dosfs/msdos_create.c: Create valid create and modfied date
and time.
CID 99
CID 100
CID 101
CID 102
* libfs/src/dosfs/fat_file.c, libfs/src/dosfs/msdos.h,
libfs/src/dosfs/msdos_misc.c: Resolve invalid use of const identified
by Coverity scanner.
* libfs/src/dosfs/msdos_misc.c: Fix PR1491.
* libfs/src/dosfs/msdos_misc.c: Part fix to PR1491.
* ftpd/ftpd.c, httpd/asp.c, httpd/ejparse.c, httpd/emfdb.c,
httpd/misc.c, httpd/um.c, httpd/webs.c, httpd/websuemf.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/nfsclient/src/nfs.c,
libmisc/capture/capture-cli.c, libmisc/monitor/mon-network.c,
libmisc/shell/hexdump-odsyntax.c, libmisc/shell/main_ifconfig.c,
libmisc/shell/shell.c, libmisc/shell/shell_makeargs.c,
libmisc/uuid/parse.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetnamadr.c, libnetworking/libc/inet_addr.c,
libnetworking/libc/inet_network.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_init.c, libnetworking/libc/res_query.c,
libnetworking/rtems/rtems_mii_ioctl.c,
score/src/objectgetnameasstring.c: Readdress use of ctype methods per
recommendation from D.J. Delorie on the newlib mailing list. We
should pass an unsigned char into these methods.
* libcsupport/include/rtems/libio.h, libcsupport/src/_rename_r.c:
Add a rename file op and have rename use it.
* libfs/Makefile.am, libfs/src/dosfs/msdos_rename.c,
libfs/src/imfs/imfs_rename.c: New files to support the rename file
op.
* libfs/src/imfs/imfs.h: Add rename interface.
* libfs/src/imfs/imfs_init.c: Add rename handler.
* libfs/src/imfs/miniimfs_init.c: Fix up ops struct.
* libfs/src/dosfs/msdos.h: Add msdos_rename and remove
msdos_file_link.
* libfs/src/dosfs/msdos_create.c: Remove the link call.
* libfs/src/dosfs/msdos_eval.c: Fix a path parsing bug.
* libfs/src/dosfs/msdos_init.c: Add rename handler and clean up
the struct naming.
* libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-link.h:
Change the link call to allow linking of directories if told to
and change the unlink to handle unlink directories that are not
empty so rename can be supported.
* libfs/src/rfs/rtems-rfs-rtems-dir.c: Fix the link/unlink calls.
* libfs/src/rfs/rtems-rfs-rtems.c: Add a rename handler. Fix the
link/unlink calls.
* libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_misc.c, httpd/asp.c,
libfs/src/nfsclient/src/nfs.c: Work around a newlib warning when
using the is*() family of calls.
16bit targets.
