#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Coverity spotted that the return code from fat_set_fat_cluster()
was ignored. But it should be because we want to return the status
that caused us to hit the cleanup path.
Simpify the loop. Set last cluster to an undefined value in case no
free cluster exists.
Separate cluster write from sector write for quick file write.
New test fstests/fsdosfswrite01.
Change block size of bdbuf to the cluster size if the data clusters are
aligned on a cluster boundary. This enables fast access to data
clusters.
Space that grows due to truncate or write offsets beyond the current
file size must be zero filled.
* libblock/include/rtems/ide_part_table.h, libblock/src/bdbuf.c,
libcsupport/src/__times.c, libcsupport/src/libio_init.c,
libcsupport/src/mallocfreespace.c, libcsupport/src/mount-mgr.c,
libcsupport/src/mount.c, libcsupport/src/rewinddir.c,
libcsupport/src/seekdir.c, libcsupport/src/telldir.c,
libcsupport/src/unmount.c, libfs/src/dosfs/fat.c,
libfs/src/dosfs/fat_fat_operations.c, libfs/src/dosfs/msdos_create.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_fsunmount.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_rename.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/shell/vis.c, libmisc/stackchk/check.c, sapi/src/posixapi.c,
telnetd/telnetd.c: Remove include of assert.h when it is not needed.
* libblock/Makefile.am: Removed src/show_bdbuf.c.
* libblock/src/show_bdbuf.c: Removed.
* libblock/include/rtems/bdbuf.h, cpukit/libblock/src/bdbuf.c:
Rewritten the bdbuf code. Remove pre-emption disable, score
access, fixed many bugs and increased performance.
* libblock/include/rtems/blkdev.h: Added
RTEMS_BLKDEV_CAPABILITIES block device request. Cleaned up
comments. Added block and user fields to the sg buffer
request. Move to rtems_* namespace.
* libblock/include/rtems/diskdevs.h,
cpukit/libblock/src/diskdevs.c: Move to rtems_* namespace. Add a
capabilities field for drivers. Change rtems_disk_lookup to
rtems_disk_obtain to match the release call. You do not lookup and
release a disk, you obtain and release a disk.
libblock/include/rtems/ramdisk.h, libblock/src/ide_part_table.c:
* libblock/include/rtems/nvdisk.h: Formatting change.
* libblock/src/blkdev.c: Move to rtems_* namespace. Change
rtems_disk_lookup to rtems_disk_obtain
* libblock/src/flashdisk.c: Move to rtems_* namespace. Use the new
support for the block number in the scatter/grather request
struct. This allows non-continuous buffer requests for those
drivers that can support increasing performance.
* libblock/src/nvdisk.c: Move to rtems_* namespace. Removed
warnings. Added better error checking. Fixed some comments.
* libblock/src/ramdisk.c: Move to rtems_* namespace. Added some
trace functions to help debugging upper layers. Use the new
* libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Use new chains
API. Removed temporary hack and changed
set_errno_and_return_minus_one to
rtems_set_errno_and_return_minus_one. Move fat_buf_access from
header and stopped it being inlined. Updated to libblock changes.
* libfs/src/dosfs/fat_fat_operations.c,
libfs/src/dosfs/fat_file.c, libfs/src/dosfs/msdos_create.c,
libfs/src/dosfs/msdos_free.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c: Use
new chains API. Removed temporary hack and changed
rtems_set_errno_and_return_minus_one. Updated to libblock changes.
* libmisc/Makefile.am: Add new ls and rm command files.
* libmisc/shell/cmp-ls.c, libmisc/shell/extern-ls.h,
libmisc/shell/filemode.c, libmisc/shell/print-ls.c,
libmisc/shell/pwcache.c, libmisc/shell/utils-ls.c,
libmisc/shell/vis.c, shell/vis.h: New.
* libmisc/shell/extern-cp.h, libmisc/shell/main_cp.c,
libmisc/shell/utils-cp.c: Fixed the usage call bug.
* libmisc/shell/main_blksync.c: Updated to the new block IO ioctl
command.
* libmisc/shell/main_ls.c, libmisc/shell/main_rm.c: Updated to BSD
commands with more features.
* score/src/coremutex.c: Fix the strick order mutex code.
* libmisc/shell/shell.c: Change shell tasks mode to be timeslice
and no ASR.
* sapi/include/confdefs.h: Change ata_driver_task_priority to
rtems_ata_driver_task_priority. Add the new BD buf cache
parameters with defaults.
* score/src/interr.c: Do not return if the CPU halt call returns.
* libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h,
libfs/src/dosfs/fat_fat_operations.h, libfs/src/dosfs/fat_file.c,
libfs/src/dosfs/fat_file.h, libfs/src/dosfs/msdos.h,
libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_dir.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/imfs/deviceio.c,
libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_directory.c,
libfs/src/imfs/imfs_fchmod.c, libfs/src/imfs/linearfile.c,
libfs/src/imfs/memfile.c: Convert to using c99 fixed-size types.
PR 515/filesystem
* src/dosfs/fat_fat_operations.c: Remove commented out code.
PR 440/filesystem
* src/dosfs/fat_fat_operations.c: Improve write speed with FAT12 and
FAT16 filesystems. Previously merged on 4.6 branch.
PR 439/filesystem
* src/dosfs/fat_fat_operations.c: Improve write data speed for DOSFS FAT12/FAT16 systems
* src/dosfs/fat.c: include config-header "config.h".
* src/dosfs/fat_fat_operations.c: Ditto.
* src/dosfs/fat_file.c: Ditto.
* src/dosfs/msdos_conv.c: Ditto.
PR 367/filesystem
* src/dosfs/Makefile.am, src/dosfs/fat.c, src/dosfs/fat.h,
src/dosfs/fat_fat_operations.c, src/dosfs/fat_file.c,
src/dosfs/msdos.h, src/dosfs/msdos_dir.c: Some bugs were still
present in the DOSFS implementation:
- FAT12 did not work properly on Big-Endian machines
- Some synchronization and error handling problems were present
- Some legal codings for EOC were not recognized
* DOS filesystem including FAT12, FAT16, and FAT32 support submitted.
* src/dosfs, src/dosfs/Makefile.am, src/dosfs/stamp-h2.in,
src/dosfs/config.h.in, src/dosfs/dosfs.h, src/dosfs/fat.c,
src/dosfs/fat.h, src/dosfs/fat_fat_operations.c,
src/dosfs/fat_fat_operations.h, src/dosfs/fat_file.c,
src/dosfs/fat_file.h, src/dosfs/msdos.h, src/dosfs/msdos_create.c,
src/dosfs/msdos_dir.c, src/dosfs/msdos_eval.c, src/dosfs/msdos_file.c,
src/dosfs/msdos_free.c, src/dosfs/msdos_fsunmount.c,
src/dosfs/msdos_handlers_dir.c, src/dosfs/msdos_handlers_file.c,
src/dosfs/msdos_init.c, src/dosfs/msdos_initsupp.c,
src/dosfs/msdos_misc.c, src/dosfs/msdos_mknod.c,
src/dosfs/msdos_node_type.c, src/dosfs/.cvsignore: New files.
* configure.ac, src/Makefile.am, wrapup/Makefile.am: Modified to
reflect addition.
