path: root/cpukit/libdl/rtl-trace.c (follow)
* cpukit/libdl: Manual file header reordering (SPDX, Doxygen, Copyright)Joel Sherrill2022-03-221-10/+11
| | | | Updates #3053.
* cpukit/libdl Change license to BSD-2Joel Sherrill2022-03-221-3/+22
| | | | Updates #3053.
* libdl: Add an archive commandChris Johns2019-03-221-6/+10
| | | | | | | - The archive command lists archives, symbols and any duplicate symbols. - Change the RTL shell commands to the rtems_printer to allow the output to be captured.
* libdl: Add symbol searching and loading from archives.Chris Johns2019-02-091-1/+3
| | | | | | | | | | | | | | - Load archive symbol tables to support searching of archives for symbols. - Search archive symbols and load the object file that contains the symbol. - Search the global and archives until all remaining unresolved symbols are not found. Group the loaded object files in the pending queue. - Run the object file and loaded dependents as a group before adding to the main object list. - Remove orphaned object files after references are removed. Updates #3686
* libdl: Include <rtems/rtl/rtl-*.h>Sebastian Huber2017-12-131-1/+1
| | | | | | Prepare for header file move to common include directory. Update #3254.
* libdl: Fix cache corruption bugs.Chris Johns2016-08-151-1/+3
| | | | | | | | | This patch fixes a number of bugs in the cache when requests are made to read close to the end of the file and the data is copied from the top of the cache buffer to the bottom of the buffer. This was compounded by attempting to read past the end of the file. Closes #2754.
* Replace www.rtems.com with www.rtems.orgSebastian Huber2015-03-201-1/+1
* cpukit: Add libdl with the Runtime Loader (RTL) code.Chris Johns2014-10-311-0/+134
This is a merge of the RTL project.
