This change requires an rtems-tools update for symbol generation.
Working architectures:
- aarch64
- arm
- powerpc
- sparc
No newlib TLS support but checked:
- i386
- m69k
Updates #4920
In rtems_rtl_symbol_global_add() the loop that gets to the end of the symbol
table used "unsigned long" to increment the index for the table. For most
architectures this resulted in 4, but with AArch64, it results in 8. This
resulted in the symbols being read in wrong. Changing this to void* along with
changing the RISC-V specific code for 8 byte pointers in rtems-tools to work
independent of the architecture.
Updates #4673
Closes #4682
Updates #3053.
Updates #3053.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
- Replace the linear object file symbol search with a binary search.
- Sort the object file symbols after loading.
Closes #3748
Prepare for header file move to common include directory.
Update #3254.
Update #2133.
Adding a local symbol lets the relocator find local symbols referenced
in relocation records. The local symbol table is erased once the object
module has been loaded.
This is a merge of the RTL project.
