* | cpukit/libdl: Manual file header reordering (SPDX, Doxygen, Copyright) | Joel Sherrill | 2022-03-22 | 1 | -7/+8 |
| | | | | Updates #3053. | ||||
* | cpukit/libdl Change license to BSD-2 | Joel Sherrill | 2022-03-22 | 1 | -3/+22 |
* | libdl: Add symbol searching and loading from archives. | Chris Johns | 2019-02-09 | 1 | -2/+0 |
| | | | | | | | | | | | | | | - Load archive symbol tables to support searching of archives for symbols. - Search archive symbols and load the object file that contains the symbol. - Search the global and archives until all remaining unresolved symbols are not found. Group the loaded object files in the pending queue. - Run the object file and loaded dependents as a group before adding to the main object list. - Remove orphaned object files after references are removed. Updates #3686 | ||||
* | libdl: Include <rtems/rtl/rtl-*.h> | Sebastian Huber | 2017-12-13 | 1 | -1/+1 |
| | | | | | | Prepare for header file move to common include directory. Update #3254. | ||||
* | cpukit: Add libdl with the Runtime Loader (RTL) code. | Chris Johns | 2014-10-31 | 1 | -0/+37 |
This is a merge of the RTL project. |
