* | libdl: Fix warnings on 64bit architectures | Chris Johns | 2022-08-05 | 1 | -3/+3 |
| | | | | Updates #4662 | ||||
* | cpukit/libdl: Manual file header reordering (SPDX, Doxygen, Copyright) | Joel Sherrill | 2022-03-22 | 1 | -8/+9 |
| | | | | Updates #3053. | ||||
* | cpukit/libdl Change license to BSD-2 | Joel Sherrill | 2022-03-22 | 1 | -3/+22 |
* | libdl/obj-comp: Add trace prints when decompressing | Chris Johns | 2020-05-05 | 1 | -0/+31 |
| | | | | Updates #3969 | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | libdl: Remove _t from all structures as this is reserved for the standards | Chris Johns | 2018-04-12 | 1 | -12/+12 |
* | libdl: Include <rtems/rtl/rtl-*.h> | Sebastian Huber | 2017-12-13 | 1 | -1/+1 |
| | | | | | | Prepare for header file move to common include directory. Update #3254. | ||||
* | Replace www.rtems.com with www.rtems.org | Sebastian Huber | 2015-03-20 | 1 | -1/+1 |
* | cpukit/libdl/rtl-obj-comp.c: Use correct printf() specification | Joel Sherrill | 2015-03-17 | 1 | -1/+1 |
* | cpukit: Add libdl with the Runtime Loader (RTL) code. | Chris Johns | 2014-10-31 | 1 | -0/+179 |
This is a merge of the RTL project. |
