* | libdl: Realloc text memory if there are trampolines | Chris Johns | 2023-08-27 | 1 | -1/+4 |
| | | | | | | | | | - Add resize to the allocator interface - Rework the trampoline variables in the obj struct to make better sense of what is happening Closes #4944 | ||||
* | cpukit/libdl: Manual file header reordering (SPDX, Doxygen, Copyright) | Joel Sherrill | 2022-03-22 | 1 | -7/+8 |
| | | | | Updates #3053. | ||||
* | cpukit/libdl Change license to BSD-2 | Joel Sherrill | 2022-03-22 | 1 | -3/+22 |
* | libdl/alloc: Add a locking interface to the allocator. | Chris Johns | 2019-02-20 | 1 | -5/+18 |
| | | | | | | | | | | | | | - Allow an allocator to lock the allocations. This is needed to lock the heap allocator so the text and trampoline table are as close together as possible to allow for the largest possible object file size. - Update the default heap allocator to lock the heap allocator. - Update ELF loading to lock the allocator. Updates #3685 | ||||
* | libdl: Allocator does not unlock and lock memory on loading. | Chris Johns | 2019-02-15 | 1 | -3/+3 |
| | | | | Close #3692 | ||||
* | libdl: Remove _t from all structures as this is reserved for the standards | Chris Johns | 2018-04-12 | 1 | -4/+4 |
* | cpukit: Add libdl with the Runtime Loader (RTL) code. | Chris Johns | 2014-10-31 | 1 | -0/+33 |
This is a merge of the RTL project. |
