utimes() now calls utimensat() to update file access
and modification timestamps.
Updated license.
Closes #4398
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
http://www.google-melange.com/gci/task/view/google/gci2012/7992211
* libcsupport/src/utimes.c (utimes): Remove casts to time_t.
PR 1597/cpukit
* libcsupport/Makefile.am, libcsupport/src/chown.c: Add lchown() and
utimes().
* libcsupport/src/lchown.c, libcsupport/src/utimes.c: New files.
