path: root/cpukit/libcsupport/src/malloc_get_statistics.c (follow)
* libcsupport: Delete malloc statisticsSebastian Huber2014-11-281-36/+0
| | | | | | | Use the heap handler statistics instead. Add heap walk option to MALLOC shell command. close #1367
* libcsupport: Doxygen Enhancement Task #8Alex Ivanov2012-12-151-2/+7
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/7996208
* Whitespace removal.Ralf Corsepius2009-11-291-1/+1
* Add locks around non-atomic structure assignment.Eric Norum2008-05-131-0/+2
* 2007-12-18 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-12-181-0/+31
* libcsupport/Makefile.am, libcsupport/preinstall.am, libcsupport/src/malloc.c, libcsupport/src/mallocinfo.c, libmisc/Makefile.am, libmisc/shell/main_mallocinfo.c, libmisc/shell/shellconfig.h: Split malloc.c into multiple files with one function per file. Also split out statistics into a separate file which can be plugged in dynamically. Right now, it is always in. I suspect that splitting the file removed more code than leaving statistics in. I tinkered with malloc information command in the shell. I resurrected the malloc arena code as malloc boundary. This code is now compiled all the time even though it does not appear to work. * libcsupport/include/rtems/malloc.h, libcsupport/src/_calloc_r.c, libcsupport/src/_free_r.c, libcsupport/src/_malloc_r.c, libcsupport/src/_realloc_r.c, libcsupport/src/calloc.c, libcsupport/src/free.c, libcsupport/src/malloc_boundary.c, libcsupport/src/malloc_get_statistics.c, libcsupport/src/malloc_initialize.c, libcsupport/src/malloc_p.h, libcsupport/src/malloc_report_statistics.c, libcsupport/src/malloc_report_statistics_plugin.c, libcsupport/src/malloc_statistics_helpers.c, libcsupport/src/malloc_walk.c, libcsupport/src/realloc.c, libmisc/shell/main_perioduse.c: New files.
