These files had no file header, copyright, or license. Based on git
history, added appropriate copyright and license.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
* libcsupport/src/getegid.c, libcsupport/src/gxx_wrappers.c,
libcsupport/src/issetugid.c: Formatting and spacing.
* libcsupport/src/issetugid.c: New (relocated from libnetworking).
* libnetworking/rtems/issetugid.c: Remove.
* libnetworking/Makefile.am: Reflect changes above.
* libcsupport/Makefile.am: Reflect changes above.
