* | cpukit/libcsupport: Adding file headers and licenses | Ryan Long | 2022-05-04 | 1 | -0/+28 |
| | | | | | These files had no file header, copyright, or license. Based on git history, added appropriate copyright and license. | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | libcsupport: Doxygen enhancement task #2 | Alex Ivanov | 2012-12-09 | 1 | -3/+5 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8017203 | ||||
* | 2007-03-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-03-26 | 1 | -0/+35 |
* libcsupport/src/assoc.c, libcsupport/src/libio.c, libcsupport/src/write.c: Split files to shrink minimum.exe. Hopefully this will not be deemed necessary to commit to the 4.7 branch. * libcsupport/src/assoclocalbyname.c, libcsupport/src/assoclocalbyremote.c, libcsupport/src/assoclocalbyremotebitfield.c, libcsupport/src/assocnamebylocal.c, libcsupport/src/assocnamebylocalbitfield.c, libcsupport/src/assocnamebyremote.c, libcsupport/src/assocnamebyremotebitfield.c, libcsupport/src/assocptrbylocal.c, libcsupport/src/assocptrbyname.c, libcsupport/src/assocptrbyremote.c, libcsupport/src/assocremotebylocal.c, libcsupport/src/assocremotebylocalbitfield.c, libcsupport/src/assocremotebyname.c, libcsupport/src/libio_init.c, libcsupport/src/write_r.c: New files. |
