* | cpukit/libcsupport: Adding file headers and licenses | Ryan Long | 2022-05-04 | 1 | -0/+28 |
| | | | | | These files had no file header, copyright, or license. Based on git history, added appropriate copyright and license. | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | basdefs.h: Add and use RTEMS_UNUSED | Sebastian Huber | 2015-10-26 | 1 | -1/+1 |
* | libcsupport: Doxygen enhancement GCI task #6 | Alex Ivanov | 2012-12-11 | 1 | -8/+5 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7992212 | ||||
* | 2012-02-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsépius | 2012-02-22 | 1 | -0/+2 |
| | | | | | * libcsupport/src/assocnamebad.c: Add #define INSIDE_ASSOC. | ||||
* | Add __attribute__((unused)) to function arguments. | Ralf Corsepius | 2009-09-15 | 1 | -0/+4 |
* | 2008-09-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-05 | 1 | -1/+1 |
| | | | | * libcsupport/src/assocnamebad.c: Correct file name in message. | ||||
* | 2007-03-13 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-13 | 1 | -5/+2 |
| | | | | | * libcsupport/src/assocnamebad.c: Remove dead code. Use PRI* macros to fix warnings. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -2/+0 |
* | 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-23 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | * libcsupport/include/chain.h, libcsupport/include/clockdrv.h, libcsupport/include/ringbuf.h, libcsupport/include/spurious.h, libcsupport/include/timerdrv.h, libcsupport/include/vmeintr.h, libcsupport/include/motorola/mc68230.h, libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/libio.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h, libcsupport/src/__gettod.c, libcsupport/src/assoc.c, libcsupport/src/assocnamebad.c, libcsupport/src/error.c, libcsupport/src/libio.c, libcsupport/src/libio_sockets.c, libcsupport/src/malloc.c, libcsupport/src/no_libc.c, libcsupport/src/termios.c, libcsupport/src/termiosreserveresources.c: Convert to using c99 fixed-size types. | ||||
* | 2001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-01-08 | 1 | -0/+4 |
| | | | | | | | * configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support. | ||||
* | 2000-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-11-01 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | * include/Makefile.am, include/rtems/libio_.h, libc/Makefile.am, libc/assoc.c, libc/assocnamebad.c, libc/base_fs.c, libc/cfsetispeed.c, libc/cfsetospeed.c, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/closedir.c, libc/dup2.c, libc/error.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fpathconf.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/ioctl.c, libc/libio.c, libc/libio_sockets.c, libc/link.c, libc/lseek.c, libc/malloc.c, libc/mallocfreespace.c, libc/mknod.c, libc/mount.c, libc/newlibc.c, libc/no_libc.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/tcsetattr.c, libc/telldir.c, libc/ttyname.c, libc/ttyname_r.c, libc/umask.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. * include/rtems/Makefile.am, include/rtems/.cvsignore: New file. * include/rtems/assoc.h, include/rtems/error.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h: New/moved files. | ||||
* | Split out the routine rtems_assoc_name_bad(). | Joel Sherrill | 1999-05-27 | 1 | -0/+37 |
