* configure.ac: Remove (Merged-in into ../configure.ac)
* Makefile.am: DOC_FILES = src/TODO src/CASES,
* src/config.h: New.
* configure.ac: Add various checks to enhance portability.
* src/termios.c: Reflect changes to configure.ac.
* configure.ac: Cosmetical fixes.
* configure.ac: Fix package name.
* configure.ac: Check for sys/cdefs.h, Add NEED_SYS_CDEFS_H.
Add check for CHAR_BIT.
* Makefile.am: Conditionally install sys/cdefs.h iff using newlib or
if the host does not provide sys/cdefs.h (Fixes Linux/posix).
* configure.ac: Remove -ansi -fasm.
Add checks to diagnose potential system header conflicts.
* Makefile.am: Unconditionally install sys/cdefs.h.
* configure.ac: Add nostdinc to AM_INIT_AUTOMAKE.
* configure.ac: RTEMS_TOP(../..).
* configure.ac: Use AC_CONFIG_AUX_DIR(../..).
Add AC_PROG_RANLIB.
* Makefile.am: Merge src/Makefile.am.
* src/Makefile.am: Remove.
Relocate libcsupport from c/src/lib to c/src/exec/libcsupport.
* configure.ac: Use ENV_RTEMSCPU. Reflect changed paths.
* Makefile.am: Reflect changed paths.
* src/Makefile.am: Reflect changed paths.
* include/sys/utsname.h: Added, removed times (now in newlib).
* Makefile.am: Merge include/Makefile.am
* libc/utsname.c: Relocated from posix/src.
* libc/Makefile.am: Reflect changes above.
* configure.ac: Remove include/Makefile
* include/sys/ioctl.h: Relocated from libnetworking/sys.
* include/sys/filio.h: Relocated from libnetworking/sys.
* include/sys/sockio.h: Relocated from libnetworking/sys.
* include/Makefile.am: Reflect changes above.
* configure.ac: Take out *NETWORKING*.
* libc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/zilog/Makefile.am: Remove.
* include/motorola/Makefile.am: Remove.
* include/sys/Makefile.am: Remove.
* include/Makefile.am: Handle subdirs, require automake-1.5
* configure.in: Remove.
