control function. The IO control handler takes now the disk device as
first parameter instead of the physical device number.
* cpukit/libblock/include/rtems/blkdev.h, libblock/src/bdbuf.c,
libblock/src/blkdev.c, libblock/src/diskdevs.c, libblock/src/nvdisk.c,
libblock/src/flashdisk.c, libblock/src/ramdisk.c: Update for block
device API change.
* Makefile.am, preinstall.am: Added statvfs.h.
* libcsupport/Makefile.am: Add statvfs.c.
* libcsupport/include/sys/statvfs.h, libcsupport/src/statvfs.c:
New.
* libcsupport/include/rtems/libio.h: Add a file system handler for
the statvfs call.
* libfs/src/devfs/devfs_init.c, libfs/src/dosfs/msdos_init.c,
libfs/src/imfs/imfs_init.c, libfs/src/nfsclient/src/nfs.c: Set the
statvfs handler to NULL.
* include/rtems/fs.h: Add a second node access field for the RFS
file system to hold a directory offset while the existing field
holds the inode number. This save a rescan of the directory when
working with directories.
* libblock/include/rtems/bdbuf.h: Added references and user fields
to the buffer descriptor.
* libblock/src/bdbuf.c: Added dynamic buffer support for different
block sizes. Fixed a number of bugs.
* libblock/src/blkdev.c: Release the disk device on an error.
* libblock/src/diskdevs.c: Set the block size to the media block
size during initialisation of the disk device.
* libblock/src/flashdisk.c, libblock/src/nvdisk.c,
libblock/src/ramdisk.c: Updated the drivers to handle variable
block sizes.
* libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Release any
buffers when an error occurs. The FAT buffer layer hangs onto a
single buffer while mounted. This should be fixed.
* sapi/inline/rtems/chain.inl: Added rtems_chain_set_off_chain,
rtems_chain_is_node_off_chain, and rtems_chain_previous.
* score/inline/rtems/score/chain.inl: Added _Chain_Set_off_chain,
and _Chain_Is_node_off_chain.
* libmisc/shell/main_ln.c, libmisc/shell/main_mknod.c,
libmisc/shell/mknod-pack_dev.c, libmisc/shell/mknod-pack_dev.h:
New shell commands.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Added ln and
mknod commands.
* libmisc/shell/hexdump-display.c: Fixed the reopen bug which
showed up as a free with a bad pointer.
* libmisc/shell/main_mount.c: List the user adding file system
when listing the available file systems to mount.
* libmisc/shell/utils-cp.c: Remove the fixed static copy buffer
and use a large dynamic buffer.
* score/inline/rtems/score/address.inl, score/src/coremsgsubmit.c,
score/src/objectallocate.c, score/src/objectfree.c: Remove
warnings.
* libblock/src/bdbuf.c: Fix group user logic.
* libblock/include/rtems/blkdev.h, libblock/src/blkdev.c,
libblock/src/nvdisk.c, libblock/src/flashdisk.c: Add set block
size, and get media block size support.
libblock/src/ramdisk.c, libfs/src/dosfs/fat.c,
libfs/src/dosfs/msdos_format.c: Eliminate using the GNU/Linux
specific error numbers EBADRQC and ENOTBLK. Switch to EINVAL and
ENOTTY as appropriate.
* Doxygen.in: Fixed project name. Added project number. Enabled auto
brief. Disabled include graphs.
* include/rtems/irq-extension.h, libblock/include/rtems/bdpart.h,
libblock/include/rtems/bdbuf.h, libblock/include/rtems/bdpart.h,
libblock/include/rtems/blkdev.h, libblock/include/rtems/diskdevs.h,
libblock/include/rtems/ramdisk.h, libblock/src/bdbuf.c,
libblock/src/blkdev.c, libblock/src/diskdevs.c, libblock/src/ramdisk.c:
Documentation.
* libblock/src/bdpart.c: Documentation. Fixed NULL pointer access.
Added const qualifier whenever possible. Added
rtems_fsmount_create_mount_point() prototype.
* libblock/include/rtems/bdbuf.h, libblock/include/rtems/diskdevs.h,
libblock/src/bdbuf.c, libblock/src/blkdev.c, libblock/src/diskdevs.c,
libblock/src/ramdisk.c: Eliminate sign mismatch warnings.
* libblock/include/rtems/blkdev.h: Remove count and start from
rtems_blkdev_request. Add RTEMS_BLKDEV_START_BLOCK macro.
* libblock/src/bdbuf.c: Add read ahead blocks always consecutive
comment. Change count to bufnum and remove start references. Sort
the transfer list so blocks are consecutive where possible.
* libblock/src/blkdev.c, libblock/src/nvdisk.c,
libblock/src/ramdisk.c: Change count to bufnum and remove start
references.
* libblock/Makefile.am: Removed src/show_bdbuf.c.
* libblock/src/show_bdbuf.c: Removed.
* libblock/include/rtems/bdbuf.h, cpukit/libblock/src/bdbuf.c:
Rewritten the bdbuf code. Remove pre-emption disable, score
access, fixed many bugs and increased performance.
* libblock/include/rtems/blkdev.h: Added
RTEMS_BLKDEV_CAPABILITIES block device request. Cleaned up
comments. Added block and user fields to the sg buffer
request. Move to rtems_* namespace.
* libblock/include/rtems/diskdevs.h,
cpukit/libblock/src/diskdevs.c: Move to rtems_* namespace. Add a
capabilities field for drivers. Change rtems_disk_lookup to
rtems_disk_obtain to match the release call. You do not lookup and
release a disk, you obtain and release a disk.
* libblock/include/rtems/ide_part_table.h,
libblock/include/rtems/ramdisk.h, libblock/src/ide_part_table.c:
* libblock/include/rtems/nvdisk.h: Formatting change.
* libblock/src/blkdev.c: Move to rtems_* namespace. Change
rtems_disk_lookup to rtems_disk_obtain
* libblock/src/flashdisk.c: Move to rtems_* namespace. Use the new
support for the block number in the scatter/grather request
struct. This allows non-continuous buffer requests for those
drivers that can support increasing performance.
* libblock/src/nvdisk.c: Move to rtems_* namespace. Removed
warnings. Added better error checking. Fixed some comments.
* libblock/src/ramdisk.c: Move to rtems_* namespace. Added some
trace functions to help debugging upper layers. Use the new
* libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Use new chains
API. Removed temporary hack and changed
set_errno_and_return_minus_one to
rtems_set_errno_and_return_minus_one. Move fat_buf_access from
header and stopped it being inlined. Updated to libblock changes.
* libfs/src/dosfs/fat_fat_operations.c,
libfs/src/dosfs/fat_file.c, libfs/src/dosfs/msdos_create.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_free.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c: Use
new chains API. Removed temporary hack and changed
rtems_set_errno_and_return_minus_one. Updated to libblock changes.
* libmisc/Makefile.am: Add new ls and rm command files.
* libmisc/shell/cmp-ls.c, libmisc/shell/extern-ls.h,
libmisc/shell/filemode.c, libmisc/shell/print-ls.c,
libmisc/shell/pwcache.c, libmisc/shell/utils-ls.c,
libmisc/shell/vis.c, shell/vis.h: New.
* libmisc/shell/extern-cp.h, libmisc/shell/main_cp.c,
libmisc/shell/utils-cp.c: Fixed the usage call bug.
* libmisc/shell/main_blksync.c: Updated to the new block IO ioctl
command.
* libmisc/shell/main_ls.c, libmisc/shell/main_rm.c: Updated to BSD
commands with more features.
* score/src/coremutex.c: Fix the strick order mutex code.
* libmisc/shell/shell.c: Change shell tasks mode to be timeslice
and no ASR.
* sapi/include/confdefs.h: Change ata_driver_task_priority to
rtems_ata_driver_task_priority. Add the new BD buf cache
parameters with defaults.
* score/src/interr.c: Do not return if the CPU halt call returns.
* libblock/include/rtems/ramdisk.h: size_t
rtems_ramdisk_configuration_size.
* libblock/src/ramdisk.c: Adaptations for 16bit target compliance.
* libblock/src/bdbuf.c, libblock/src/ramdisk.c,
libcsupport/src/newlibc.c, libcsupport/src/sync.c,
libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-symbols.c,
libmisc/shell/cmds.c, libmisc/shell/shell.c,
libnetworking/kern/kern_sysctl.c, libnetworking/lib/ftpfs.c,
libnetworking/lib/tftpDriver.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetnamadr.c,
libnetworking/libc/inet_addr.c, libnetworking/libc/linkaddr.c,
libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_print.c,
libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c,
libnetworking/libc/rcmd.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c,
libnetworking/libc/res_send.c, libnetworking/libc/res_update.c,
libnetworking/net/radix.c, libnetworking/rtems/mkrootfs.c,
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/svc.c,
score/macros/rtems/score/chain.inl, score/src/objectidtoname.c: Too
much was accidentally committed -- revert.
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/rtems_rpc.c,
librpc/src/rpc/svc.c, sapi/include/confdefs.h,
* include/rtems/blkdev.h, include/rtems/ide_part_table.h,
src/bdbuf.c, src/ide_part_table.c, src/ramdisk.c:
Switch to using c99 fixed size types instead of RTEMS-types.
* Makefile.am: AM_CPPFLAGS += -I$(top_builddir).
Use AM_CPPFLAGS instead of AM_CFLAGS.
* src/ata.c: Include config.h.
* src/bdbuf.c: Ditto.
* src/blkdev.c: Ditto.
* src/diskdevs.c: Ditto.
* src/ide_part_table.c: Ditto.
* src/ramdisk.c: Ditto.
PR 385/filesystem
* src/ramdisk.c: The "from" and "to" locations are calculated as
the start of the block within the ram that data is to be transferred
from/to for reads and writes respectively. However, within
the loops, the "from" and "to" locations are never updated. The loop
should have been updated as:
from += rd->block_size;
and
to += rd->block_size;
within the for loops in the ramdisk_read and ramdisk_write routines,
respectively.
* src/ramdisk.c: include <string.h>.
* src/blkdev.c: include <string.h>.
* Submitted by Victor V. Vengerov <vvv@oktet.ru> and merged
into the RTEMS source.
* ChangeLog, Makefile.am, README, configure.ac, include/Makefile.am,
include/rtems/bdbuf.h, include/rtems/blkdev.h, include/rtems/diskdevs.h,
include/rtems/ramdisk.h, include/rtems/.cvsignore, include/.cvsignore,
src/Makefile.am, src/bdbuf.c, src/blkdev.c, src/diskdevs.c,
src/ramdisk.c, src/.cvsignore, .cvsignore: New files.
