This is already in the error path.
brains GmbH.
Updates #4625.
Updates #3053.
Currently if mount fails, a converter isn't destroyed. We have to take
care of two cases:
1. The user doesn't provide a converter.
In this case mounting a dosfs creates a default converter. This patch
makes sure that the converter is destroyed again if mount failes for
this case.
2. The user provides a converter.
In this case it's not sure that the dosfs specific routines are reached
because mount can fail before that. Therefore the user has to destroy
the converter himself again. This patch adds a documentation for that
and implements it in the media server.
Closes #4042.
This adds the possibility to request a retry in the media-listener if an
operation failed. Usefull for example if you want to automatically
reformat a disk if it wasn't possible to mount it.
Update #2843.
Drop superfluous <stdlib.h> include from <rtems/diskdevs.h> since this
leads to conflicts with the latest Newlib in case this header file is
used in the FreeBSD kernel space, e.g. for USB mass storage support.
This area is protected by the media mutex.
The functions
o rtems_bdbuf_get(),
o rtems_bdbuf_read(),
o rtems_bdbuf_syncdev(), and
o rtems_bdbuf_purge_dev(),
use now the disk device instead of the device identifier. This makes
bdbuf independent of rtems_disk_obtain() and rtems_disk_release(). It
is the responsiblity of the file system to obtain the disk device. This
also reduces the overhead to get a buffer.
The key for the AVL tree uses now the disk device instead of the device
identifier. The pointer is interpreted as an unsigned integer. This
reduces the memory overhead and makes the comparison operation a bit
faster.
Removed function rtems_bdbuf_purge_major(). This function was too
destructive and could have unpredictable side effects.
CID 114/SECURE_CODING
* libblock/src/media.c: Avoid strcpy().
* libblock/src/media.c: Use unprotected chain extract.
* libblock/include/rtems/media.h, libblock/src/media-desc.c,
libblock/src/media-dev-ident.c, libblock/src/media-path.c,
libblock/src/media-server.c, libblock/src/media.c: New files.
* Makefile.am, preinstall.am, libblock/Makefile.am: Reflect changes
above.
