* inline/Makefile.am: Remove.
* macros/Makefile.am: Remove.
* src/Makefile.am: Remove.
* Makefile.am: Merge-in removed Makefile.ams.
* src/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/Makefile.am: Use AM_CPPFLAGS instead of INCLUDES.
* configure.ac: Remove references to RTEMS_BSP.
* src/Makefile.am: Add libitron.a.
Use ../aclocal.
* inline/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* macros/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* inline/Makefile.am: Remove AUTOMAKE_OPTIONS.
* macros/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/Makefile.am: Add multilib support.
* src/Makefile.am: Revamp INCLUDES handling to make automake-1.5
* src/Makefile.am: Include compile.am.
that contains:
* Removes MKLIB
handling)
