path: root/cpukit/include/sys/statvfs.h (follow)
* sys: Add files to Doxygen groupSebastian Huber2023-07-261-3/+4
| | | | | | Canonicalize brief descriptions. Update #3707.
* cpukit/include/sys: Change license to BSD-2.Joel Sherrill2022-03-251-3/+22
| | | | Updates #3053.
* Remove explicit file names from @fileSebastian Huber2019-02-281-1/+1
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* Remove make preinstallChris Johns2018-01-251-0/+60
