path: root/cpukit/include/rtems/termios_printk.h (follow)
* libmisc/serdbg: Remove obsolete serial debugJoel Sherrill2023-02-091-116/+0
| | | | Closes #2828.
* cpukit/include/rtems: Change license to BSD-2Joel Sherrill2022-03-251-3/+22
| | | | Updates #3053.
* cpukit: Automated IMD header file clean upChristian Mauderer2022-03-101-1/+1
| | | | | | Use the same form of IMD in all copyright lines Update #4625.
* bsps and cpukit: Manual file header clean upChristian Mauderer2022-03-101-18/+14
| | | | Updates #4625.
* Remove make preinstallChris Johns2018-01-251-0/+101
